I recently had to clear the hoses with a small kitchen snake because a small article of clothing was blocking the pump. Since doing this the spin tub fills along with the wash tub and the wash tub drains while the spin cycle is running. What could I have done to cause this to happen? The water level does not reach the overflow which is the usual cause for the spin tub filling. Thank you
SOURCE: No pressure to drive swing arm.
Check first that no debris is blocking the holes in the spray arm where the water comes out, and clean out the holes. In case it will not solve your problem, it's look like a pump problem (the pump has two functions : drive water to the spray arms and to drain water out the washer). Open the rear panel and listen if the pump works during the wash cycle. In case it doesn't work, it should be replaced. Good luck !
SOURCE: Danby DDW396W won't drain
If you remove the cover, you will discover that there are two motors inside. The larger one on the right runs to fill the machine and spray the water during washing. The smaller one on the left drains it. Oiling this motor, or manually actuating it by spinning the wheel between cycles may solve your problem.
SOURCE: Tank still fills when we are using direct drain feature
check to see that the hose isn't clogged, and that the hose runs down hill from the tank all the way to the drain. if it is higher than the tank at any point in its path it will not drain. you may put the dehumidifier on top of a small platform to aid drainage. also check that the knockout removed so there is a hole to let the water go from the tank to the hose?
SOURCE: Won't wash
I didn't realize that you have to let the faucet run the entire duration of the wash cycle. But that was the problem.
SOURCE: drain hose not working
Hi, had the same problem. Not a glogging one. I have the model DDR503H. If it is insisting on filling the reservoir, it is because you haven't put the cap you removed from de back of the unit to plug the hose on the tank water exit. You have to first remove the tank and on the roof of this space, you will see the water tank exit where you can screw the cap removed from the back. You place back the tank into the unit and now the water won't have other choice then leak thru the hose. Also. to clean up the filter, I don't need to unscrew the top cover. I just remove the tank and on the roof of the space, there is a grey handle with arrows on it and I just pulled down, it comes out and you can then clean it up.
Hope this help,
Steeve
