Each wheel/brake has its own sensor which reports back to the computer. If the sensor or wire to the sensor goes bad it kicks on the abs light. The cheaper code readers will not diagnose abs troubles. The higher end units with built in abs feature will tell you which circuit is bad, front left, right rear, etc. if all sensors working and no abs light on you can assume all is well.
