It depends on which program you are using. In Microsoft Word, to change the space between all lines in a paragraph, click the Home tab. Then in the Paragraph group, click the Line Spacing button. A popup menu should appear. Select your new line spacing value. The line spacing is set for the current paragraph or all highlighted paragraphs.
I guess you can change fonts using control characters but I don't know if you can embad tham in a word doc. No way to test it because I don't have this printer.I remember having done it in early days of DOS word processing with Wordstar.
Hold ALT and type the command character - the numbers 27. In notebook will look like an arrow to the left, followed by writing a command character, examples: ? P Selects 10 cpi ? M Selecting the 12 CPI ? ? Select dense Print - 15 CPI (this character is typed by holding the ALT key figures 15)
As far as I can tell ther is no way to change the line spacing on the Calender Creator Delux edition. However, there is a work around. You can find out how here: Margins Line Spacing.
Hope this helps!
Normally this is a software control (application) for example Word. For example, on the Home menu of the Word screen, about midway across the screen, you will see the character spacing blocks, just to the right of those you will see a small box with up and down arrowheads. This is the box to click on to set the line spacing.
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Change the settings in MS word. Your looking for line spacing. Set line spacing to 1. Can't find line spacing? Open Help, type in the search window (line spacing). Try printing now.
