If it has bluetooth try this hope it helps.
1. Press and hold the multi-information meter switch for about 2 seconds or more to switch from the setting mode screen to the menu screen.
Refer to "Changing the function settings (when the ignition switch is "ON")".
2. Lightly press the multi-information meter switch to select (language cooperative control).
3. Press and hold the multi-information meter switch to switch in sequence from A or 1 (language cooperation enabled) ? M, 2 or P (language cooperation disabled) ? A or 1 (language cooperation enabled).
The setting is changed to the selected condition. Note
? The memory of the language cooperative control is erased if the battery is disconnected, and it returns automatically to A or 1 (language cooperation enabled).
? The language display modified with the language setting can be switched in the following manner.
• When A or 1 (language cooperation enabled) has been selected with the language cooperative control, the language for MITSUBISHI Multi-Communication System (MMCS) (if so equipped) or the Bluetooth® 2.0 interface (if so equipped) is automatically changed to the language selected for the multi-information display.
• When M, 2 or P (language cooperation disabled) has been selected with the language cooperative control, the language for MITSUBISHI Multi-Communication System (MMCS) (if so equipped) or the Bluetooth® 2.0 interface (if so equipped) is not automatically changed to the language selected for the multi-information display.
Pairing is not the same thing as connecting. The LED will go solid when you complete the next step which is connecting. With headsets that is usually done via the audio source device.
I did this to my HF1000 Handsfree device this evening as I had mine in chinese language as well today.
Power up the unit the vioce will say power on, wait for silence then push and hold the Call button, the unit will speak the pairing instructions including the pair code of 0000. regardless of the language the voice will repeat the number four times, so even thought you might not understand it, you will hear the number repeat....
After a brief silence period, press and hold the call button again, the next announcement is the language selection menu. After the announcement press the Volume + (plus) button to change the langauge, this announcement is quite long. Wait for each announcement (they are maybe two full sentences long).
Press the plus (+) Volume button to again to change to the next language, wait the appropriate length of time and press the plus Volume key again, for the next language....
Chinese language is directly after English, and so you need to go throught the key press sequence about I think five times. English, then Chinese, Italian, Spanish then German, is the sequence I believe.
Hi! Click the "Start" icon, go to "Settings" from the drop down menu, click "System" (which is the 2nd tab) and then click "Regional Settings" (the globe icon). Then choose from the drop down menu the language you prefer. Hope this helps!
Hi!
Hope this helps!
Hi!
Just click the Start Menu, go to settings, click System tab, then click on the Regional Settings button. Choose the language from the drop down menu. Restart your phone.
Hope this helps!
