Motorcycles Logo
A
Anonymous Posted on Sep 05, 2014
Kawasaki wiring diagram
Where do you tap into tah factory wiring harness to adapt add on lighting?
eric white
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 87 Answers
  • Posted on Sep 08, 2014
eric white
Expert
Level 2:
New Friend:
Cheetah:
Answers
87
Questions
Helped
16964
Points
107
You dont. you add another relay and circuit for the new lights
3 Related Answers
Anonymous
  • 130 Answers
  • Posted on Jun 07, 2009
SOURCE: i need a wiring harness
http://rapidshare.com/files/58031637/KR-1.zip
click the above link and download the service repair manuals.it has all the wiring harness diagrams on it and are easy to understand.
goodluck
thanks and please do not forget to rate the solution and keep updated.
Anonymous
  • 6966 Answers
  • Posted on Aug 15, 2009
SOURCE: wiring diagram for kawasaki klr 250
Hi and welcome to FixYa,
Have you tried here?
Good luck and thank you for asking FixYa.
Anonymous
  • 426 Answers
  • Posted on Feb 20, 2011
SOURCE: I want to wire in
http://www.repairmanualclub.com/motomanuals/index.php
In my 2004 grand prix gt Where do I attach the extra red wire in my stereo wiring adapter package ,the directions say hook it to the fusebox ,but how exactly ?
well best is real kit from these maker.
uses the factory radio harness
all this avoids cutting and wrecking factory harnesses.
https://www.scosche.com/car-audio/installation/harness
or buy fuse trap, this is pigtail wire and fuse as one.
to tap ignition fuse or accessory fuse or best of all the factory radio fuse.
https://www.amazon.com/Circuit-Inline-Holder-Assortment-circuits/dp/B014K93ROM
1helpful
2015 Ford E350 Super Duty Stereo Wiring Diagram
I would see if there was an adapter harness for the stereo to your harness first. When you replace the factory stereo, you will loose many functions the radio controls. You will loose chimes, you can't reset oil life and other things. It will take a scanner to reset or change certain options. $90 to throw a scanner on a vehicle where I work. The radio you get has about 12 wires to it. The factory harness has about 20. Those extra wires are data lines. You don't want to patch into one of them. And some of the data wires are the same color as speaker wires. Also if it has an amp in it, that is additional wiring that has to be done. The aftermarket won't run it.
Need to find out how to put wiring on
Kawasaki Motorcycle Wiring Diagrams
www.classiccycles.org/1852/597943.html
Kawasaki BN125 Eliminator 125 Electrical Wiring Harness Diagram Schematic HERE... Kawasaki GPX600 Ninja GPX 600 Electrical Wiring Harness Diagram ...Missing: tpgs
Kawasaki Motorcycle Service Manuals
www.classiccycles.org/1852/1894.html
Kawasaki BN125 Eliminator BN 125 Workshop Service Repair Manual HERE ...Kawasaki GPX600 Ninja 600 Electrical Wiring Diagram Schematic 1988 to 1991 ...Missing: tpgs
WIRING DIAGRAM thread for all sorts of bikes - Bike Chat Forums
www.bikechatforums.com/viewtopic.php?p=2322761
Oct 11, 2009 - 25 posts - ‎7 authors
this is the new wiring diagram thread, requests allowed .... http://i574.photobucket.com/albums/ss182/hmmmnz1/Honda/th_cb600f.jpgCB600f ...Missing: tpgs
Jan 27, 2016 • Motorcycles
Need the pin to pin wiring schematics for this model of motorcycle?
    More images for 1990 Kawasaki 650R wiring schematic
    Kawasaki Motorcycle Wiring Diagrams - ClassicCycles.org
    Kawasaki Motorcycle Electrical Wiring Diagram Schematics. ... Kawasaki GPZ600 GPZ 600 Electrical Wiring Harness Diagram Schematic 1988 to 1990 HERE ...Kawasaki KZ650 Z650 KZ Z 650 B Electrical Wiring Harness Diagram Schematic ...
    Owner Center - Kawasaki
Jan 21, 2016 • Motorcycles
1helpful
2answers
I'm looking for a factory wiring diagram for my 1999 vw passat.
Hi Chad,
If you cut the car's radio connectors off the wiring harness, you'll void the warranty of the car (or worse). Trying to splice or "tap" the wires will get confusing even if you don't connect the blue wire with the white stripe to the white wire with the blue stripe.
Do yourself a huge favor and purchase a wiring harness adapter for your 199 Passat instead. Crutchfield sells one for your car for $10. Likewise, most electronics stores that deal witrh mobile installs have them too - check out Best Buy, Circuit City, Fry's and even your local independent radio shops.
You wire the new radio's harness to the harness adapter for the car in the comfort of your home (the light is better and you don't have to contort yourself to do the work). When complete, bring it out to the car and plug one end into the car, and the other into the radio. Insert the antenna plug and you're done wiring!
If you want a wiring diagram, those usually aren't available online for free. You need to spend a few dollars for a Chilton's Auto Repair Manual or similar at an autoparts store. You may find registering at a site for Passat Enthusiasts will be beneficial.. all the folks there have Passats and discuss everything from tire sizes and rims to transmission rebuilding. One such site is the "Forum" section of Passat World.
I hope this helps & good luck!
I have no harness for vehical was told the reason I have no sound is becuase the pink and black wire labeled Audio interrupt lead were does this connect 2
The install diagram indicates the Audio Interrupt wire goes to a Vehicle Phone. If you don't have one, don;t connect it to anything andmake sure you put tape over the end so it doesn't touch ground or a power source.
In cases where I don't have or cannot get a wiring harness adapter to plug directly into my vehicle wiring harness I have a trick I like to use. I don't like to cut and remove a vehicle harness socket, I may want to keep the aftermarket stereo when I sell or trade and put the original stereo back in place. Instead of removing the socket I skin back (but do not cut) the wires I need to tap into and wrap the aftermarket unit's wires around the now exposed socket wiring, then solder each one & wrap each one individually with electrical tape. This gives you a secure connection and when and if you need to permanently remove the aftermarket unit you just untape the wires, clip the fatermarket wires off one at a time very close to where they are tapped in, tape each one of them again and there you have the factory plug ready to plug back into the factory stereo.
Installing after market radio need factory wiring diagram for 1996 ford f150
Try chrutchfield.It is easy to spend a couple of bucks for a adapter.Then you just wire the radio an plug it in to the factory harness.You can also try any local box store that installs radios,they will have the adapter harness.Well hope this helps.
I want to add in some mirror mounted LED lights, like the newer vehicles (the lighted arrows in the mirrors). I've got the led's I want, now I need to know which wire to tap in to (at the door wiring...
the easiest spot to tap into would be up at the front turn signal trying to find the correct wire in the factory harness where all the wires are together is going to be really tough to do if you pull the front turn signal out and use a meter it should be fairly simple to find the positive wire there.
Installing after market stereo
Dave,
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Sincerely,
JC
Top Motorcycles Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Motorcycle Expert? Answer questions, earn points and help others
