Sony Ericsson W960i  Cellular Phone Logo
A
Anonymous Posted on Sep 04, 2014
How my phone lcd blank white but,touchscreen still work?
Yancsy Gyorgy
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Jan 11, 2015
Yancsy Gyorgy
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
0
Helped
6010
Points
47
Try update software hard reset
1helpful
Screen cracked
Probably it won't be usable because the sensors on the screen is corrupted. You need to replace it with a brand new screen.
5helpful
Blank and white screen solution
Hi,there are two kinds of white screen in phone,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage lcd the phone will detected
by computer because its software is still working...so ,
the problem of your phone am sure is the second one ,
corrupted software....your phone needs to reprogram,and
need to go to the model of the phones care center to fix you problem...
And also flex can make screen go blank and or white.(if it is a flip phone)The flex is a connector that connects the screen to the phone board of the phone.That can also be the cause, when the flex is damaged,it can cause blank and white screen display .
i hope ,i will help you ,thanks for trusting fixya...
Sep 16, 2010 • Cell Phones
1helpful
White screen
The LCD display is defective and needs to be replaced. Your touchscreen is probably OK, unless its been physically damaged.
The touchscreen can be salvaged if OK.
Please see this link to have this problem resolved:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
HALF OF MY LCD IS WHITE
If at you the white screen, it means that the loop has torn. Such usually happens on phones of such type.
http://heaters.agilityhoster.com/
2helpful
Dropped iphone with WHITE Screen
Hi
There might be a Flex cable that disconnected in the phone, you will need to bring it to a cell phone shop or apple to have a look at it.
David
CellUnlock.net
7helpful
2answers
Blank white screen
It seems to be ur lcd stops working..Take this to service center...
1helpful
2answers
My screen is blank
Is the screen white or just dark?
Fix Sidekick White LCD Screen
If it dark or no light at all then
replacement of the Sidekick 3 LCD flip screen.
to buy a sidekick 3 lcd screen look here.
http://www.repairmysidekick.org/Sidekick-LCD-Screens/buy-a-t-mobile-sidekick-3-lcd
Look for one that has the torx screwdriver included
Sidekick screen blank
Call T-mobile if the phone is still under warranty. They may fix it for you.
If not follow this procedure, it usually works.
3answers
Blank screen
i have the same phone and the problem just lies on the flexcable inside the phone that attached the keypad to screen.
1helpful
3answers
My sidekick3 screen is blank
If your sidekick ID or Sidekick 3 screen is a blank white, then the lcd flex cable has come loose. It is a little difficult to repair but any one can do it. The worst that will happen if you try to repair yourself is that it will not work and you buy a replacement screen from ebay for 45 dollars.
Here are the detailed instructions. Just reinstall your lcd instead of putting a new one on.
Sidekick 3 LCD Screen Only Replacement
Here is a link to find lcd screen on ebay.
Sidekick 3 LCD Lens
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
