How do I replace incline motor? The incline motor stopped working- have new motor but need instructions. thanks!
Unplug unit and remove the motor cover. there are two bolts that hold the incline motor in. one on top of unit and the other on the bottom of the lifting screw. make sure incline is all the way down. follow the wiring to the control board. removed them off the board noting which ones go where and color orientantion. instillation is reverse of removal
SOURCE: I have a nordic track a2350 and the belt stopped
This is usually related to the control pwb which is located under the motor "hood".
You can get this part from iconservice.com by going to the replacement parts section of the site and entering the model number of your machine, Which is located on the lower frame assembly below the walk belt. After you have receieved the part you can follow this procedure to repair it.
http://www.fixya.com/support/t3807308-belt_goes_full_speed_when_started_shuts
SOURCE: Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
SOURCE: Nordic track S3000 model 291050
First of all, here is the ONLINE USER'S MANUAL for that model:
http://www.iconservice.com/CustomerService/manualsProductManuals.do?model=NTL29105&modelName=NORDIC+TRACK+S3000+TREADMILL&version=0&company=11&language=
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated or the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
See page 23 of the ONLINE USER'S MANUAL for detailed instructions on how check if the unit is in DEMO MODE.
When the console is in the demo mode, the power cord can be plugged in, the key can be removed from the console, and the displays and indicators on the console will automatically light in a preset sequence, although the buttons on the console will not operate.
If a D appears in the display when the information mode is selected, press the SPEED button so the display is blank in order to return to normal mode of operation.
See page 24 of the manual for other troubleshooting procedures such as resetting the motor breaker located near the power cord connection on the treadmill.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Joe.
SOURCE: Belt on Nordic Track T4.0 treadmill stops
Dear Sir:
1) Lube the treadmill in according with the instruction manual.
2) The reason is lack of lube by maintenance, that produce enough friction with shut down for to protect electronic system.
3) Test the deck belt if is worn, and replace it.
4) Test the rollers bearings
5) See the bearing motor
6) Test the input voltage motor coming from the output from the main motor board,, use DVOM.
7) See my personal TIPS for HELP.
sincerely. God bless you
SOURCE: Why does my Nordic Track Reflex 4500 Pro incline automatically when I start it up?
You must tried again the s.calibration, for easy diagnose, and troubleshooting.
However you must Adjust the speed sensor, test it, clean it, and tight any plug or connector, see the diagrams attached and proceed according.
2) Lube the elevation motor, the shaft + gear, test the motor itself for open or short. see the diagram attached. If you machine use RELAIS test it for dirty, or open and repair.
God bless you
