Bosch WFF washing machine error codes:
E1 - The door is not closed and cannot therefore lock.
E2 - Washer will not fill with water.
E3 - Washing machine not heating.
E4 - Washing machine won't empty.
E5 - Fault in the motor drive circuit.
E6 - Unexpected heating.
E7 - NTC thermistor open or short circuit.
Please note that the codes for the WFF range of Bosch machines differs from other ranges.
SOURCE: Bosch Maxx WFL 2060
connect at random. put on a rinse cycle. if cold water comes in then pipes are correct. if hot water comes in then pipes are wrong way round and just swap them
SOURCE: My bosch WFL 2060 Front Loader Washing machine stops mid-way ..
hiya
i'll need a little more info if you can, like what exactly does the machine do or not do?
does it make any strange noises?
does it trip out the electics?
the more you can answer for me the better the diagnoses
thanks kj
SOURCE: Replacement front door for a Bosch Axxis WLF 2060
Visit repairclinic.com. Enter your model number in the search box and it should call up the parts you need.You'll be able to see actual photos of the parts on size grids so you can compare with what your's look like.
I did a quick search and it looks like you're looking for part number 1046685 .
SOURCE: bosch washer wfl 2050/ 2060 door is locked and
Tom
Unplug it from the power source.
It should release it if not you have a sticky selenoid that locks your system.
If freed. great.. but you need to have that selnoid replaced, because it will happened again.
If the power interruption doesn't work, you need to dismantle your system.
If still under warrenty... Cal a service guy
SOURCE: Bosch Axxis WFL 2060 won't
Have you checked for any blockages, in the drain pipe? If that doesn't help you might have a bad pump, here's the part:
http://www.appliancepartspros.com/modelsearch_model.aspx?model_id=232480&pkw_=pump
Testimonial: "Very fast response and provided 2 proposed solutions, so I'm pleased with the result. Got my machine whirring away-for free!"
