I can't touch the screen to unlock it
SOURCE: unlock code for HTC Touch pro 2 tmobile
You
can easily get your htc unlocking code online.when i suffered with the
problem and i wanted the code then my friend suggested me the site from
where i got my htc unlocking code.click here to get your unlock code.
hope this helps..
SOURCE: hi how can i unlock my htc wildfire its on 3,for
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 1122 or 000999
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: unlocking my htc wildfire a3333
As you have not specified in particular what is the unlock code required for you, i am giving the ways to unlock all the codes
NETWORK UNLOCK CODE:
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your mobile is not an CDMA mobile , you can get the network unlock code(NUC) by just contacting the current network provider customer care department.It is free of cost.
The restriction code can be got from your old service provider..This restriction code is kept to prevent someone who stole the mobile from using it with another provider...
They will have a security check done with your date of birth etc..to verify whether you are the exact owner of the phone..
After that they will provide you the restriction code to unlock it and use it with another service provider..
It is all free of cost do not pay anyone for this seeing some advertisement over internet . That is all fake ads.
The above procedure works and you can verify that by seeing the rating of an happy customer here..
http://www.fixya.com/support/t4979448-need_unlock_motorola_razor_v3_from_optus
PUK CODE:
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3079596-sking_puk_code
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
SECURITY CODE:
If it is lost nothing can be done. You need to flash your mobile at an authorized service center which will reset the mobile memory and also all the data inside the mobile will be lost.
A helpful rating and an testimonial would be greatly appreciated if you are satisfied with the solution i have posted.
SOURCE: how to unlock my HTC wildfire mobile phone? locked
Hi,you can try superunlockcodes to get unlock code for your mobile and get it unlocked safely..
SOURCE: Can you get free codes to unlock the htc wildfire
Dont trust free unlocking it wont unlock your mobile properly . Only trust best unlocking specialist , unlocking via codes is the best way for unlocking the mobile , follow the instructions here mobileunlockguide , then get the unlock code here mobileunlocksolutions , using unlock code specified in it proceed unlocking your mobile without vain ..
1. Power on your HTC mobile phone with an unaccepted SIM card in (or no SIM card at all).
2. Enter your 8-digit unlock code you attained earlier.
3. Your HTC mobile phone should be unlocked and may automatically reboot!
These free unlock instructions provided above only work with GSM or SIM card versions of the HTC Wildfire.
I think helps.Let me know
Chandrashekhar
