I think the dishwasher gets stuck at the point where it is supposed to heat the water. If it can't heat the water (because the heating element isn't working, or because the heater relay inside the controller is bad), then it may stay there indefinately. In other dishwashers, the timer/controller will give up after 3 or 4 hours and finish the cycle. In others, the dishwasher will shut down and indicate an error condition.
Normally if you started the rinse cycle with water already in the base of the dishwasher it will immediately go into circulating the water through the wash arms. Do you hear the wash arms running when the washer is stuck at 11mins? Also when the washer is stuck at 73 mins are the wash arms running all the time or do you hear the pump operate at some stage? If you have the dishwasher manual available make sure the water pressure setting is at HI or LO depending on your rated mains water pressure.
If your Dishwasher is stuck in a cycle check the following
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board God bless you use the VOM..
Float Switch
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/control electronic. Use the VOMGod bless you
It can be the issue with defective float switch. The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. One more thing, if your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
see this causes and fix it. God bless you .Float Switch
Timer / Control
will need to replace the timer /electronic control
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
see this causes, use the common sense.God bless you Dishwasher Stuck in a Cycle
Float Switch
Timer / Control
