Question about Transmission & Drivetrain for Kia Amanti Sedan
What cause the transmission not shift in drive
It shift into reverse ok
    President:
  • 1,273 Answers
Try the easiest possibility first.....check the fluid level.
Posted on Sep 05, 2014
SOURCE:
How do I fix My kodiak 400 that will not shift into reverse or park
as soon as your bike begins to high idle it will not fall into gear you probably will need to set your linkage on your shifte
Sep 01, 2014 | Yamaha 2004 Kodiak 400 Auto 4x4
Transmission park &reverse not shifting into gear only gets drive need a why need solkution ?
run fault codes and check for a TCM problem or servo/ solenoid s for the gear selections.
Apr 25, 2014 | Ford E-150 Cars & Trucks
Atv wont shift into high gear
Is this an electric shift?? SORRY.. take it to a qualified professional!!
Sep 02, 2017 | ATVs
I have a Evinrude Ficht 135 that Runs Ok but won't go in to gear, forward or reverse. Any ideas?
Disconnect the shift cable and see if the problem is with the shift box or the lower unit. If the lower, remove the bottom plug and look for water or metal where there should be clean oil.
If the shift box, take to the marina- they were a bear. Even just for cables.
Jun 17, 2012 | Light Boating
Have had an intermittent problem with putting the car in reverse. When reverse would engage it would work ok. Now won't shift into reverse at all. Still forward gears drive and shift ok. Also car would...
is this a automatic transmission or a stick if its a stick could be clutch plate when you put it in reverse and it does nothing its an internal problem sorry have a free check done of it at a transmission shop
Nov 29, 2010 | 2002 Mercury Mountaineer
Transmission doesn't shift in reverse after it warms up
it is safty in the tranny have it scan
Oct 12, 2009 | 1991 Audi 100
Auto tranny slipping after shifting out of second
Firstly is it slow for reverse, reverse clutch also engages in 3rd gear however reverse has a boosted circuit (more psi) therefore will engage rev but not 3rd but it is a little slow for reverse.
They do have a tendancy to pop a ball out of the High and reverse clutch giving this symptom.
May 07, 2009 | 1991 Nissan Stanza
1991 colt vista wont downshiftinto 2nd and reverse had to shift
Ok man here is what i think, you should replace the input and output speed sensers.
Jun 17, 2008 | 1991 Dodge Colt
Transmission & Drivetrain for Kia Amanti Sedan Logo
51 people viewed this question
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Cameron Lewis
Cameron Lewis
Level 1 Expert
Kardoc
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
