Remove the bowl by removing one bolt from directly underneath it. The bowl is a silver metal cylinder shaped piece.
After removal, you will see a small almost pin sized hole. It is probley clogged up. Take a needle, small nail, anything that you can insert into the hole to clean out. Also blow through the hole.
You may need to repeat this a couple times but it will work!
Rebuild sounds very intense. You can more than likely take the bowl off the bottom of the Carb And clean the Jet that runs up the center.
The Center, being where the Small bolt came from that you took off to get the bowl down. These Honda engines have VERY small jets, they clog easily.
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
SOURCE: I have a Craftsman self-propelled lawnmower that will not start.
first remove air filter and spray starting fluid in the carb? if it starts the fuel is the problem carbs are easily removed and cleaned make sure needel is not stuck? if it dosnt start chexk for spark pull rope hold screwdriver over wire touch it too plug end see if you see spark if not? then you must test zone conrol cable and grounds? did you hit something hard with the blade if so you could have a sheered flywheel key it will trow egine out of time ?
SOURCE: Honda, self propelled lawn mover. GVC 160. Used
Could be Flywheel Key, Coil and Do buy a New Spark Plug. Make sure Head bolts are tight.
SOURCE: I am trying to find a free instruction manual for
Go to Honda Website , you should be able to get it from there.
