Tumi Dakota Fishermans Friend Angler II Accessories Alarm Watches Logo
L
Linda L Palmer Posted on Sep 04, 2014
How to repace batteries on dakota fisherman pocket watch?
What size battery is in a phillip crow pocket watch
Pop the back off the watch with a pocket knife and look, they use so many types of small button batteries it is hard to say, better to look at it and record the battery number.
1helpful
Changing the battery in a mickey mouse pocket watch
The first answer is a canned answer. Seen it before. Examine the edge of the pocket watch. Start at the stem and look for a slight gap where the back cover meets the case. It is usually at the stem side or hinge side. Once located take a strong sharp knife and carefully pry up the back cover. It should remove fairly easily. I have about 12 pocket watches and they all work the same way. Once open there may be a small screw or two holding the battery in place. You will need a precision screw driver set or a small screw driver for glasses.
682b943c-dbb9-4041-9abb-ed1a67105d52.jpg eff96e41-9266-48e7-9603-ac9206c667a0.jpg 03735b42-603a-41af-9aa7-4d445bd017dc.jpg
Jun 30, 2013 • Watches
How do you change the battery in a calibri pocket watch ?
go to the store where u bought the watch....or any store where there sell batteries the normaly will exchange and fit it for u
2answers
My watch has stopped working
mcdevito75 here, Unless you have a good knowledge of takeing apart, even just the back off your watch / pocket watch it"s best to look for a small watch repair shop in your area, but here is what you can do to possibly start your watch / pocket watch. If your watch / pocket watch hasn"t been wound in some time and that time varies from watch to watch, the oil in the watch can become a bit thick so as to not allow the mechanism to work smoothly, leave the watch / pocket watch in a warm place, window sill in the sunlight wrapped in a paper towel for anywhere between a few minutes to 1/2 hour, after the watch / pocket watch has been warmed up hopefully the oil in the mechanism has liquified enough to allow the movement to start working. You can also give the movement a little boost, after the watch /pocket watch is warm, pull out the stem as if to set the time of day, move the stem and hands, sometimes this action will get the watch ticking again. If this fails, BEST BET specially if this is an expebsive or keepsake watch, look for a small watch repair shop in your area for serviveing. approx. $45.00
1helpful
Watch battery number for dakota watch
This watch requires a size 1620 battery, available at all Dakota Watch Company store locations, and most electronics stores. Dakota Watch Company always recommends taking your watch to one of our store locations or a reputable jeweler to reduce the risk of damaging your watch during a battery change.
We are sorry to read of your trouble with receiving technical support. We will be happy to answer any questions regarding your Dakota watch. Please feel free to contact our Customer Service by email at [email protected], or by phone at 1-888-459-0404. Thank you!
3helpful
How do I change the battery of a Jules Jurgensen pocket watch.
First you have to get an eyeglass and examine watch caseback. Can you see the joint or is it monoblock? If there is joint, get strong knife and press into it. Some of watch casebacks are very tight, so, apply great pressure but do not let the blade slip or you will damage the movement.
If the case is monoblock, then you have to open it from dial side.
Be very carefull when doing it as any slip of the blade will damage your watch.
Good luck.
37helpful
3answers
Replaceing battery for colibri pocket watch
Hi, replacing battery can be found on amazon, take a look here: Rayovac Batteries Lasts as Long Costs Less. Wish you best of luck.
Top Tumi Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Tumi Watch Expert? Answer questions, earn points and help others
