Televison & Video Logo
S
Sawblv Posted on Sep 04, 2014
I have power but no picture
TV would turn off then I would reset,then nothing. Then it would turn on a few minutes later. Now power light goes on when plugged in fades out. On and off is pressed light stays on, no picture. Have to unplug to turn off power to the TV
Circuit Surgeon Electronics
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Sep 22, 2014
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
377
Points
8
Check or have the power supply checked of defective capacitors.
5 Related Answers
Anonymous
  • Posted on Oct 21, 2008
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Anonymous
  • 61 Answers
  • Posted on Jun 01, 2009
SOURCE: TV freezes at "Philips" screen
a professional. -These electronics go threw a self diagnostic when they start up, normally they turn off when they find a problem.
Anonymous
  • 556 Answers
  • Posted on Aug 11, 2009
SOURCE: Sony kdfe60a20 - The TV turns on but after a
classic Sony telling you the lamp is going bad. Replace lamp yourself it is consumer replacable.
rulds2008
Grand Canyon Tech
  • 3867 Answers
  • Posted on Aug 31, 2009
SOURCE: My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Oct 24, 2009
SOURCE: My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
2answers
TV not turning on
I can almost guarantee the issue is caused by faulty capacitors in the power supply but it is not something I recommend you to work on yourself because there is a danger of electric shock.
The capacitors will have dried out and there are lots of companies now selling power supply refurbishment kits but this does mean de-soldering and re-soldering a selection of components and if the de-soldering is not done properly, it is easy to rip electrical plating out and effectively make the power supply scrap.
I estimate a local TV repair company would charge for about 1 hour labour and parts cost and would be reasonably priced at about 50-70 UK Pounds.
1helpful
Hard to get started when powering up to watch.
definitely, something wrong with it. TV shouldn't take more then a few seconds to start, I suggest, while it still under warranty, give Sharp a call to get it fixed.
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
