I have allready changed the vss rear speed sensor and it didnt change any thing.what woud you suggest i change now
SOURCE: speedometer not woking shifting hard 1993 ford f150 4x4 -302
when i bought mine the speedometer odomoter and raido didn't work
put in a fuse that wasnt' in got them all and now when u are driveing it shifts out of gears or sometimes it wont shift past first any ideas?
SOURCE: Intermittent speedo for 1991 Honda accord but odometer & trip ok
its a faulty speed sensor or plug to speed sensor could be dirty
SOURCE: changing spark plugs 95 chevy lumina van
you will have to take off the coil packs and move them out of the way. then go in from the top. its kinda tight but just move whatever else is in the way
SOURCE: won't shift out of first gear
good diagnosis that is correct if the vehicle speed sensor is not working the speedo doesnt work and the trans doesnt know when to shift
Testimonial: "EXCELLENT"
SOURCE: 1998 Dakota 5.2 P0500 No speedo and ABS and Brake light on
sensor in rear diff may need replaced
