What does error message er:0:11 mean on a 703 seca scale
SOURCE: Hi i have a Seca
Hi pethkars,
You may do the following to helps you solve the issue with the Error that you are getting:
1. Switch off the scale with the Start key and start the scale again. The scale will then
work normally again.
2. If this is not the case, disconnect the power supply by briefly removing the batteries.
If this measure is equally unsuccessful, the last option you have is to inform the Service department. This will require advance troubleshooting that only people from Seca can provide. You may reach them through this.
Hope this helps.
Thank you for using FixYa.
SOURCE: I have a Seca 703
This could be a power issue. Make sure your battery pack wire connections are good. If they are loose, I suggest purchasing the Seca 400 power adapter, which works with this model.
