Dictaphone M5215 Walkabout Digital Recorder - Pre-Owned Logo
J
Joan Butler Posted on Sep 04, 2014
Where can I buy usb cable for Dictaphone m5215 in South Africa?
The usb cable for my Dictaphone m5215 has been mislaid and I can't transfer files to my computer - where can I buy one in South Africa?
Anamack
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 23 Answers
  • Posted on Sep 04, 2014
Anamack
Contributor
Level 1:
New Friend:
Cheetah:
Answers
23
Questions
0
Helped
1999
Points
55
Use bluetooth or file clouding
tip
Tutorial HOW TO FLASH a Samsung SGH - J700
1) STEP1: Search Firmware (Some links where you can download them):
1.1) Firmware files are coded like this:
[Model] [Location] [Year] [Month] [Version]
----- [Location] -----
CP Finland
DB Vietnam
DC Thailand
DD India
DT Australia
DX Malaysia, Indonesia, Vietnam, Philippines, Singapore
JA South Africa
JC Tunisia, South Africa, Nigeria, Morocco, Algeria
JP Arabic
JR Arabic
JV Tunisia, Syria, South Africa, Saudi Arabia, Pakistan, Oman, Nigeria, Morocco, Kuwait, Iraq, Iran, Egypt, Algeria
XA United Kingdom, Switzerland, Netherlands, Italy, France, Germany, Austria
XB Sweden, Denmark, Norway
XC Portugal, Spain
XD Slovakia, Hungary, Czech, Croatia
XE Ukraine, Russia, Bulgaria, Lithuania, Latvia, Estonia, Kazakhstan
XF Croatia, Romania, Bulgaria
XX United Kingdom, France, Austria, Belgium, Germany, Hungary, Italy, Spain
ZC Hong Kong, China
ZT Taiwan
----- [Year] -----
a: 2001,b: 2002,c: 2003,d: 2004,e: 2005,f: 2006,g: 2007,h: 2008,i: 2009
----- [Month] -----
a: January,b: February,c: March,d: April,e: May,f: June,g: July,h: August,i: September,j: October,k: November,l: December,
Example:
J700XAHD1
XA: United Kingdom, France, Austria, Belgium, Germany, Hungary, Italy, Spain
H: 2008
D: April
1: rev1
1.2) Download:
Note: You need 3 files!: [.tfs], [.cfg] and a [.bin or .cla] file.
2) STEP2: Make serial connection to phone:
2.1) Two ways to get a connection with your phone:
2.1.1) Buy a USB to SAMSUNG connector (Not the one you get with your phone. You must buy it). (Expensive)
I dident buy a cable but you can find aSamsung E210 / G600 / L760 USB Flash Cable here (this is compatible with the J700):
http://www.fonefunshop.co.uk/datacables/samsung.htm
Note: dont buy a DATA SUITE CABLE but a UNLOCK / FLASH CABLE!!! (So on the webpage of fonefunshopscroll all the way down).
2.1.2) DO SOME ELECTRONICS (Cheap!)
I did it like this because i had everything i needed anyway. Most peolpe probably wont but you can find the components i use in every electronic shop or online via websites like http://www.farnell.com/
What I did was making this scheme and used a USB to serial converter cable because I didn't had a COM port:
You need:
- MAX232 in a 16pin DIP package
- 4 x 10µF Capacitors
- A serial connector (female or male: depends on the cable you use to connect to your PC).
- An old USB cable you can strip to get a clean power of 5V.
- And serial cable of course (I used a USB to serial cable but if you have a COM port you can use simple old serial cable)
I have soldered the wires directly on to the pcb at the back of the phone connector. I used some old IDE cable for it. When soldering you will notice the connector pins are very small so only solder 1 sup copper wire of the bundle to the bcp. Pretty difficult but with a magnifying class it is possible.
Use tape to secure everything because. Try to put the little pcb back into the phone and connect the 2 plastic flat cables back onto it.
1.jpg2.jpg3.jpgNote: I didn't use the USB cable for a stable 5V but and 7805 so the first picture shows a little bit more components than what is needed.
3) STEP3: Download FLASH Software and FLASH IT!
3.1) Download flash software
This is what we need:
oneNAND Downloader v1.4 for pnx5230
You can find it here:
http://www.mediafire.com/?dke0xjtddm2
http://www.mediafire.com/?j3alvnn0ymz
http://rapidshare.com/files/175511787/OneNAND_Downloader_v1.4_Lite_for_PNX5230_tfs4_v1.6_.rar
ect...
3.2) FLASH IT!
Start oneNAND and do like I did on the photo:
  1. Turn off your cell phone.
  2. Then click START.
  3. When he shows you this message: **(POWER ON the PHONE!)** just push the power button shortly. (1sec is enough).
  4. oneNAND Downloader will now try to identify the oneNAND chip inside the cell phone.
  5. If all is well he would say something of 256MB ...
  6. Then press DOWNLOAD and wait for 2 hours and your phone will be flashed with the firmware.
  7. Finished!
Have fun!
on Jan 18, 2010 • Cell Phones
1helpful
HI, I have a 1 Terabyte SAMSUNG External Hardrive. The USB Connector broke off, but I can see my data if I hold the connector to the circuit board. Will I be able to purchase SIMILr circuit board for...
Hello
I think you'd be better of with buying a external box to put the drive into it . You need to cautiously break the original box open and proceed with the transfer .
Best regards ,
fanaudi .
Which transfer program for dictaphone m5220 works with windows 7?
You can use either Walkabout Transfer or Walkabout Write found here:
https://isupport.nuance.com/OA_HTML/csksxvm.jsp?nSetNumber=13097
Also, if you connect the portable via USB to your PC, it'll connect just like a USB memory stick and you can use Windows Explorer to transfer your dictation from the 'DSS' folder.
1helpful
I want to transfer files that were recorded on a dictaphone on to another dictaphone to play. How do I do this? The files are the same format and when I move them the dictaphone doesn't have them to play
Can't you simply take the tape from the 2750 and put it into the other Dictaphone to play it? Or is the other Dictaphone a different size tape (eg; mini or micro)?
Faulty Usb cable so I cannot download my sessions
try cutting the cable head that goes into the voice recorder and buying any USB cable extention and attaching the colored wires then solder them lightly and wrap a tap around each one of the cables then wrap te bundle and try it. just be carefull not to add too much soldering and keep cable from touching each other.
Top Dictaphone Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Dictaphone Office Equipment and Supply Expert? Answer questions, earn points and help others
