? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
SC542 is a heating roller warm up error. Most likely the fuser lamp has failed - a faulty sensor or board is also possible but not very likely. You'll need a new fuser, I suspect.
This is the correct solution to resolving SC542 error on a Ricoh SP3410 SF and SP3510SF:
Press Clear/Stop button once and then press 1 0 7 and then the Start button to enter the "Engine Maintenance" in Maintenance Mode. Select "Fuser SC Reset" and execute..press ok. Turn main power on and off. Issue will be resolved.
Change the thermistors in the fusor (2).
1. Press the Clear Mode key.
2. Use the keypad to enter .107..
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
Turn off and on the copier to reset the code.
