What is wrong and how do I know which part to get
Code 23
  • Washing Mach... Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect. If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash. Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8 Check this link to replace the inlet valve: http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin. Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump. Please check the link below: http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Sep 04, 2014
SOURCE:
I would like to know what Error300 means on a Canon Super G3.
there is no error 300 on this model
g3 is a fax standard---all current fax machines on the market are G3 not a machine model
Jan 12, 2015 | Canon imageCLASS D-480 - 23 PPM...
Modem name: MMX310G 3G USB Manager At port: COM 23
IMEI: 910532501150347
Please provide the nck code for MMX310G 3G USB Manager
Thanks
sthita_50@yahoo.co.in
Sep 28, 2013 | Computers & Internet
Wrong exponential value
Sorry, but there is nothing wrong with the exponential notation on your calculator. There is however a misunderstanding from your part on the priority rule of operations.
The sequence 0.030377/6.022x10^23 is interpreted as (0.030377/6.022)x10^23 while you wanted 0.030377/(6.022x10^23), dividing by Avogadro's Number.
How to fix it. Enter the power of 10 exponent (10^23) using the EE key. In other words Avogadro's Number should be typed in as 6.022 [EE]23. If you do not have the EE key you must use parentheses to enclose the whole number (6.022x10^23) or use the division key twice /6.022/10^23
On a calculator a sequence a/bxc where both operations have the same level of priority is executed from left to right.
Nov 03, 2012 | Texas Instruments BA-II Plus Calculator
I have an engine code 23 on my R1 and it also doesnt seem to have as much power that i think it should have. Does anyone know what the engine code 23 means?
Error 23 meaans that the atmospheric sensor is faulty or the wiring associated with it may be faulty see your dealer to locate this sensor,they are about $100
May 30, 2011 | Yamaha NB 125E Motorcycles
Code 1,2,7,8,23,55 1999 dodge caravan
1/2/7/8/ are not in the code system code 23 intake air temp. sensor either to high or to low. code 55 end of message. hope this will help!!!
Apr 12, 2010 | 1999 Dodge Caravan
Code C:31:23
Already replied.
Error C:31:23 problem means that System Control is not getting Supply Reel pulse. This can be electronic or mechanical problem in camcorder.
Qualified camera tech will fix it properly.
Feb 22, 2009 | Sony Handycam CCD-TRV318 Camcorder
Sony DSR error code C31:30 & C31:23
Error codes definitions are bit technical and as follows...
C:31:30 error code shows problem of No FG signal when starting capstan motor.
C:31:23 error code shows problem of No S reel signal to system control.
Above info were taken from service manual and picture of service manual can be seen below...
Need further info, let me know.
Oct 28, 2008 | Sony DSR-45 Mini DV VCR
Sony DCR-TRV19 Problem: None of the functions except cassette ejection will work. Error Code:C:31:23
Error code 31:23 shows problem in Take-up Reel section of your Sony Camera. If you know about camera repair, please check Take-up Reel section in tape mechanism and if you don't know, please contact nearest Sony Service Center for proper repair.
Aug 17, 2008 | Cameras
Erro code f23-1
If its F2- 31 , its the drum mark problem.The drum may be defective or the wrong drum fixed on a machine.Also clean the drum mark sensor on the drum unit.
Jul 30, 2008 | Office Equipment & Supplies
I have a sony dcr-trv 245e buy an error code c31:23 keeps coming up. anyone know whats wrong? thanks , jay.
Yes, I know whats wrong in your camera. Its mechanical problem related to take-up reel section.
Jul 23, 2008 | Cameras
Washing Machines Logo
181 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
