How and what can I do, to fix my frozen Nikon COOLPIX S3300??
I dropped it when it was on. the camera turned off but the lens is still popping out. The green light is on but is not turning off what should I do to fix my Nikon COOLPIX camera.
Re: How and what can I do, to fix my frozen Nikon COOLPIX...
Sounds like internal damage. If you've removed the battery for more than 20 minutes and it still behaves in this fashion your best option is to send it in for repairs or purchase another, which may be a cheaper option.
These camera's will do that when the battery is very low sometimes.
I'm not sure that is your problem due to lack of more details, but it is a possibility.
Coolpix s3300 does not have any other viewfinder, your LCD panel is your only viewfinder. By default it cannot be turned off.
Please provide more informations so that I can help you.
I would remove the battery and re install some times this works. If you have some real physical damage it may be cheaper to buy a new one than repair if it's a point and shoot camera good luck
It seems rather apparent that you broke your camera when you dropped it. Since you publicly admitted you dropped it, Nikon isn't likely to cover it under warranty. It looks like you need a new camera...
Sorry if that wasn't the answer you wanted but if you break it, you buy it.
Sorry, but there's no simple DIY fix, and any homebrew repair attempts will likely make the damage worse. Your camera's warranty won't cover the damage, so I suggest that you take it to a local camera shop (NOT the camera department in a chain store) or contact customer service via the nikon.com web site to arrange repair. Be sure to get a firm price before you commit to anything though. The fix can easily approach the price of a new camera, and repairs typically only carry a 30-day warranty.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
