Photo paper jams every time I try to print photos
SOURCE: Paper Jam with no Jam
You may have overloaded your paper feeder with heavy card stock and caused a very tiny jam that you have not found yet so that it will act oddly as it is. Look right up inside unit with a torch and down back where the paper goes in.Try printing on plain a4 agian, place a small stack in feeder, reset paper guides too. Also could be your paper sensor, fixable under warranty.
SOURCE: Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Testimonial: "tried blowing and dusting with a brush Now it comes on as normal - no flashing light but will only take paper about 2 cms then flashes paperjam"
SOURCE: Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets
1.
Open the paper support and raise the extension.
2.
Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams.
Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time.
Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.)
4.
Open the output tray and pull out the extension.
You should also follow these guidelines:
Always load the short edge first, even when you’re printing landscape-oriented pictures.
When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package.
Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
SOURCE: Epson Stylus Photo R350 giving a paper jam error message
An Epson service man (he was VERY kind to suggest this) told me to use a weak detergent solution on the rollers, NOT alcohol as that will dry out the material the rollers are made of. Although the problem has recurred a couple of times, it's worth repeating when necessary. I actually activate the 'print' command so it tries to feed in paper, while I FIRMLY hold a piece of fine cotton cloth stretched over a thin plastic ruler, which I hold down where the paper feed grabs its paper. The printer has a couple of tries to feed paper, reports an error message (because there was no paper) and I activate it again, thus exposing the WHOLE of the feed wheel to the cleansing cloth! WORTH A TRY!
SOURCE: paper jam error
Dear Sir,
I have Epson Stylus-1390 Photo Printer. Problem is when giving photo
printing option thru printer driver printer get error is paper jam..
can you give me solution for the same.
thanks
