There are a couple of ways to achieve this.
First, press 355 on your phone to activate the call forward feature. Once it asks for a forward destination, press whatever number your company uses to dial an outside line. After that dial your number like normal and hang up the phone.This will forward all calls directly to your cell phone.
The second method is the same as the one listed above but it uses the feature code 356. 356 will forward calls if you do not answer from your Mitel phone first.
I hope this helps
Create
a new account with a third-party text message management client
such as Google Voice, which is free to
use. There is a link in the Resources section.
Set
up your cell phone to synchronize with the online client. Create a
new online number that you may use through your cell phone if
necessary.
Add
the numbers to additional phones. These numbers will automatically
receive forwarded text messages when you receive them on your cell
phone.
Add
additional accounts if you prefer. Google Voice, for example,
allows you to forward text messages to your email inbox.
God bless you
Figure out if your particular cell phone model has the option to forward incoming calls. You can do this by visiting your cell phone manufacturer's website or reading the manufacturer's manual that came along with the purchase.
Access the "Settings" menu on your cell phone and select "Phone Settings" menu.
Select the "Call Forwarding" option in the "Phone Settings menu. This option is usually found at the bottom of the "Phone Settings" menu. Selecting the "Call Forwarding" option gives you access to call-forwarding controls.
Switch on the "Call Forwarding" slider. The default position is off.
Insert the phone number you wish to forward your calls to in the "Forward To" field. This field most commonly lies below the "Call Forwarding" slider.
Exit the setup menu by pressing the home button. You may be asked to confirm/save the changed settings depending on your cell phone model.
Make a test phone call to the cell phone number on which you just enabled the call rerouting option. If the call is forwarded and received on the number you entered, it means that the "Call Forwarding" option has been activated.
