HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
A
Anonymous Posted on Sep 03, 2014
PRINTER DOCUMENT IN QUEUE WILL NOT DELETE WINDOWS 8
5 Related Answers
Anonymous
  • 1605 Answers
  • Posted on Jan 29, 2009
SOURCE: Docs in queue won't cancel so I can print another document
turn of the printer and unlug the data cable.
go to start>>printer and faxes, open the printer queue and deleted the job.
plug in the data cable and turn on the printer
Anonymous
  • 499 Answers
  • Posted on Jun 09, 2009
SOURCE: hhp deskjet 5550 - orange and green light keep
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons. 4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
Anonymous
  • 23 Answers
  • Posted on Sep 25, 2009
SOURCE: I had my printer (hp psc 1200 series) try and
You need to go ahead and simply refresh a service known as "Print Spooler"
here's how you do it..
for Windows XP:
>> click on start
>> click on run
>> type in " services.msc " and hit enter
You will see a list of service names alphabetically arranged on the right hand side..
From there look for the service name "print spooler"
>> right click on it
>> click on stop
wait for 10 secs
>> right click on it again
>> click on start..
>> restart the computer..
>> you will find your document deleted :)
plz rate if you find it helpful. thank you
Anonymous
  • 241 Answers
  • Posted on May 28, 2010
SOURCE: hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
nonontech
Lebanon Raingam
  • 4737 Answers
  • Posted on Jun 02, 2010
SOURCE: It says HP psc1315 printer is offline and won't
Reset your printer. To do this, turn off the printer using the power button, remove the cartridges, unplug the power and the usb cables. Press the power button for several times. Connect the power cable and also the wall jack, power on (don't connect the usb cable). While the printer boots up, keep pressing power button several times. Leave it for few minutes and again switch off. Now connect the usb cable as well and insert the cartridges. Shutdown the computer. Power on the printer and also the computer (Note when you power off/on, use only the power button). This will fix your problem. If possible, please reinstall the drivers for your printer before you restart it with the pc. Good luck. Thanks for using FixYa.
How to Remove a Stuck Document That Won\'t Delete from a Windows PC Printer Queue?
Unplug printer from wall. Reboot computer. Check that document is gone before plugging printer back in. NOTE, "unplug from wall" does not mean "turn printer off". Unplug it.
HP Photosmart Plus 209a-m doc in queue won't delete
using windows explorer, go into windows/system/spool/printers and erase contents in last item
1helpful
My printer is on and connected and my computer recognizes it. I selected it when I printed and it says "1 document in queue" but it won't print. How do I fix this?
Delete the document in queue, press Ctrl+Alt+delete at the same time and select 'Task Manager'. If the Print Queue is still appears in 'Applications' select and stop it. Turn off printer and Restart P.C., when P.C. is ready turn on the Printer fingers crossed Print Queue is no longer there. You should be able to carry on printing.
Thumbs up please if this works for you, thanks
23helpful
2answers
Document stuck in queue and will not delete or print.
Its a common problem. All you have to do is to restart the Print Spooler service and delete the print queue. To restart the service follow the steps: Open Control Panel > Administrative Tools > Services. Now find service named "Print Spooler" and right click over it and select "Restart" to restart the service.
Now open the "Printers and Faxes" folder and try to delete the print queue. Now you will be able to delete the print queue. If applicable you can follow the steps once again if any print queue refuse to get deleted.
Once the print queue is empty, you can print from your printer smoothly.
Cheers!
Printer keeps printing page after page of meaningless symbols.
Did you have document in queue?If you have delete all documents in queue and restart the computer.Then restart printer.Wait to document in queue deleting.If you haven't documents in queue reinstall the drivers.First delete old, reset computer and install new.
7helpful
Document won't delete from printer queue after printed
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side window.
On the left side click stop the service and wait forthe process to stop .Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them depending apon how many print jobs you submitted. You will have to resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
Failing to cancel a document from queue
When a document does not cancel, it is probably due to a Print driver error. I would delete the printer from the printer queue. Then click on add printer and reinstall it again. It should see the driver and reinstall. If this does not work, re-install the printer from the cd..
Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
2answers
Unable to clear printer queue
I had a related problem. Couldn't delete a job from the queue nohow. I wound up deleting various processes (CTRL ALT DEL PROCESSES tab) and it cleared it.
k24674
Grand Canyon Tech
Grand Canyon Tech
