Question about Compaq Evo N610C Notebook
Compaq Evo doesnt turn on.
When I turn on the power button, the lights blink and make a wierd clicking sound, but then it goes dead. It was working fine. It down start up at all, not even the screen will turn on.
  • 3 Answers
I encountered a similar issue with my n610c a while back. It turned out I had no ram (it had all been removed). This may not be exactly what you are looking for, but it happened to me.
Posted on Jul 03, 2009
  • 1,056 Answers
When you plug the laptop to the power adapter, you should see the indicator led lit up telling that it has good connection to the ac adaptor. It wont turn on because either there is a loose connection to the power adaptor and hasn't been charging the battery, or the power adaptor itself is bad. Check the power plug with a miltimeter, it should be around 19 Volts.
Posted on Jul 02, 2009
SOURCE:
My compaq 610 wont start up. went i connect de charger the powerbutton lights goes on en off.
When the power button blinks do you hear the laptop fans run on full speed? If that happens its because your laptop is overheating and is trying to cool down. It will not turn on until it cools down to protect from damage due to heat.
Use your laptop on a hard surface and dont block its vents with anything. If you want to use it on bed keep it on a laptop cooler or a thick book to allow ventilation.
If laptop doesnt turn on at all, the motherboard might be damaged. Take it to repair shop and check whats wrong.
Nov 01, 2013 | Compaq Evo N610C Notebook
How to get my laptop to charge.
If you battery is totally dead you need a replacement unit - remove the battery power the unit up using external power pack then refitt the battery - if it won't charge the battery is dead. get a new battery
May 19, 2010 | HP Compaq Evo n610c Notebook
I Have A Compaq Evo N600c Laptop No Power Help!!!
Yeah it could be. Always use the correct adapter mentioned for your laptop. Otherwise it could harm the inner wirings and the motherboard. Always go for the right adapter. If it was any motherboard problem, atleast it would've blinked. So this might be the problem of your adapter or may be of the power button.
Apr 18, 2010 | Compaq Evo N600C PC Notebook
How do you turn it on
I have compaq Evo N610c, which would not start when i press the power button, & when i press the power button or slide reset button the battery led blinks umber 8 times and then green 1 times of the HDD led.what should i do, would you please help me, thank you//
Jan 15, 2010 | Compaq Evo N610C Notebook
I have a compaq presario V5204NR
Try starting it with just the adaptor or just the battery.
If the adaptor is broken it might not properly power-up, same goes for the battery. You'll need to exclude these two first.
If it starts with just the adaptor: dead battery.
If it starts with just the battery: defective adaptor (broken connections, insufficient power etc.)
In both cases you should probably call upon your warranty. That is, it that is still applicable.
If both situations don't work, let me know and we'll think further.
Greetings,
DarkNeogen.
Jun 20, 2008 | Compaq Presario Notebook
Keyboard not working on evo n1000c
hi, first check the keyboard is on (there is power on for the keyboard and mouse device in the newer type of laptops) and while the windows start before boot see the num light is blink and the power on will blink. if it will not blink. Goto the bios setup and here while you switch on the system press the DEL or F2 key. it will goes to the bios setup and see the keyboard is enable. if it will not work then you have check with the other usb or ps/2 keyboard connect it and try it . if prob comes again inform to fixya.com
bye jennifer
Jun 11, 2008 | HP Compaq Evo Notebook N1000c
No power on
cheak the all battery points.
Jun 10, 2008 | Compaq Evo N610C Notebook
Evo n610c
The computer's power light may blink to indicate that there's a problem with the power from the AC adapter.
Mar 25, 2008 | HP Compaq Evo n610c Notebook
Compaq Evo N610C Notebook Logo
174 people viewed this question
Top Compaq Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
