Computers & Internet Logo
Posted on Jul 02, 2009
My boss wants his Microsoft 2007 Outlook Calendar on his Iphone.
My boss wants his Microsoft 2007 Outlook Calendar that he runs under parallels on his mac to sync with his Iphone. I believe all of our files are under an exchange server. Any detailed help would be appreciated.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jul 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1161
Points
6
Http://support.apple.com/kb/TS1347
i googled your question and found the apple page. in case it doesn't load or is blocked, run the setup wizard for outlook first, then sync after because outlook will not sync unless it has made the file first
2answers
Syncing my iPhone 5s with outlook 2007 and vise versa
Go to the Microsoft support site the instruction are there.
Jun 01, 2016 • Cell Phones
2answers
Sync'ing outlook 2007 with Toshiba PocketPC 2002 e335
nope ....the outlook 2007 doesnt support all the connecting devices
3answers
Outlook calendar appointments sync to IPhone but appointments made in Iphone do not sync to Outlook
so what u trying and wanting to do with it here being coneected meens its looking at whatever in i pohone not what u did before cuse if u set it to work online it would edit the date so ya set it offline so it dont think its contecting online program so trricky what and do u have latest firmware in i phone and updates for office outlook ?
The answer to "Share Calendars" that comes up in
The option is usually under where you are looking at:
How to Share Calendars
Open a Shared Calendar
Share My Calendar
If the option is not there, then you can go to File>Folder>Share Calendar
Hope that helps, pls rate the solution
1helpful
How can I set Outlook so that it's separate access for my boss and I to communicate or for me to view his calendar (mirror)? Can I do this? HOW? Please provide the printscreen pics. Not sure why, but...
1. How can I set Outlook so that it's separate access for my boss and I?
r:/ question: are you both (you and your boss) using the same computer account?, as long as you have outlook installed and if your boss and you are using different accounts you should have separate access to outlook.
2. view his calendar (mirror): usully you would need an exchange server, if you do see if this helps: sorry I have no pics but try to follow the instructions and post back with your questions:
this is assuming you have outlook 2003
In Calendar, in the Navigation Pane (Navigation Pane: The column on the left side of the Outlook window that includes panes such as Shortcuts or Mail and the shortcuts or folders within each pane. Click a folder to show the items in the folder.), click Share My Calendar.
1.
HideI don't see Share My Calendar
Share My Calendar does not appear unless you are using an Exchange Server e-mail account. What is an Exchange Server account? Also, if you have the Navigation Pane turned off or covered by the main Calendar window, you won't see it. Hide or show the Navigation Pane.
2. Do one of the following:
HideAllow anyone to access your Calendar
1. In the Name box, click Default.
2. Under Permissions, in the Permission Level list, click the permission level that you want.
For details about permission levels, see Outlook folder permissions.
You can create custom permissions by selecting the check boxes and options under Permissions.
HideSpecify the people who can access your Calendar
1. Click Add.
2. In the Add Users dialog box, in the Type Name or Select from List box, enter the name of the person whom you want to grant sharing permissions to.
3. Under Add Users, click Add, and then click OK.
4. In the Name box, click the name of the person you just added.
5. Under Permissions, in the Permission Level list, click the permission level that you want.
Important If you select the Private check box on a Calendar item in Microsoft Office Outlook 2003, do not grant Read permission to your Calendar folder to anyone whom you do not want to see private items. A person who is granted Read permission to access your folders could use programmatic methods or other e-mail applications to view the details in a private item.
source:
sharing a calendar in outlook
now if you don't have an exchange server you may need another tool to make this work: like officecalendar, or try to see if the instructions proposed in the following link work
good luck!
Archive Calendar
check with microsoft for an update, any problems with outlook is microsoft's baliewick. www.microsoft.com/outlook upgrade.
Sync iphone 3g calendar w/outlook 2007
In itunes go to syncing options and make sure contacts and calender are selected! then resync! hope this helps! Merry christmas!
4helpful
Editing private appointment of a shared calendar
In your boss outlook do the following.
Tools --> Options --> Delegates
Select the delegates and click permission and enable check mark "Delegate can see my private items"
2answers
Syncing outlook 2007 and iphone
BUY A BLACKBERRY. NO PROBLEMS HERE
Grand Canyon Tech
Grand Canyon Tech
