Televison & Video Logo
A
Anonymous Posted on Sep 03, 2014
Tx-p42x50b will not turn on after power cut
Panasonic tx-42x50b television will not turn on after a mains power cut.power now reinstated to t/v ,fuse ok to plug.all connections to set in place
Chris Frost
Level 3:
  • Master 985 Answers
  • Posted on Sep 08, 2014
Chris Frost
Master
Level 3:
Answers
985
Questions
0
Helped
217898
Points
3239
Most likely it's a capacitor fault triggered by the power cut.
Google "Capacitor bulge" and then search Youtube for your make and model to see if anyone has done an instructional video. You'll need to be comfortable dismantling the TV and be able to use a soldering iron. If this isn't you then take it to a repair shop.
5 Related Answers
marionbagget
  • 718 Answers
  • Posted on Feb 17, 2009
SOURCE: How do I remove the stand from a panasonic tv. model TX - 32LXD70
The stand is held on by four screws. Lay the tv face down on a flat surface. Cover the surface with a blanket first. Use a regular phillips screw driver. (If you have a users manual see page 7)
The screws are the set just above the stand on the back of the set. The stand will then slide out.
Anonymous
  • 2098 Answers
  • Posted on Dec 26, 2010
SOURCE: i have panasonic television.fault its
resolder the cold solder around the audio and amplier section.....
Anonymous
  • 325 Answers
  • Posted on Apr 06, 2011
SOURCE: Sharp Model LC-37BD60U : There was a thunderstorm
The fuse is internal nearest the point of where the 120VAC contacts the power supply. The fuse will be brand specific BUT will be a slow-blow ceramic (white). Replace with only the exact same rating of fuse to avoid fires within the tv.
Hope this helps and please rate!
Anonymous
  • 998 Answers
  • Posted on Sep 04, 2011
SOURCE: Tevion LCD4203ID, turned televsion on
Sir try to check the fuse in the power supply may be damage. Remove the back cover of your unit but be sure to unplug the unit from the main ac outlet. Then look for the fuse, if the fuse is defective, before replacing it observe if the fuse is totally burned if you see this sign don't just replace the fuse it indicates that it has a shorted parts in the power supply common parts are the regulator and bridge type rectifier, but if the fuse is just broken or still you can see the wire you can replace it and try to check if the unit will power up. Good day and best regards.
Anonymous
  • 1182 Answers
  • Posted on Aug 06, 2012
SOURCE: how do i remove the narration from my panasonic 42 in tx-42x50b
Kindly go through operation manual of every device and follow guidelines step-by-step.
Panasonic TC-L47DT50 no picture no sound front lights com on
No picture or sound in my Panasonic TH-P42UT30A plasma ...
https://www.ifixit.com/.../No+picture+or+sound+in+my+Panasonic+...
iFixitAug 1, 2014 - Hi Ifixit,. I've got a Panasonic th-p42ut30a plasma tv that has a fault with it. The standby light is on (red) but it doesn't come out of standby.Missing: l47dt50
Panasonic Product Support - TC-L47DT50
shop.panasonic.com > Get Support
PanasonicSMART VIERA® 47" Class DT50 Series Full HD 3D LED HDTV (46.9" Diag.) ... Issues Addressed: Solves issue where the Emergency Alert System is displayed on the TVhours after the termination of the message. Solves issue where the Emergency Alert System is displayed on the TV hours after ...
Panasonic TX-P42X50B No Picture Or Sound ' Dead ...
? 9:00
https://www.youtube.com/watch?v=EanHoWLLpxU
Nov 6, 2014 - Uploaded by Electronic Workshop
Panasonic TX-P42X50B No Picture Or Sound This plasma television ... TV repair, clicking and will not power on, loud snap,no picture, etc.
Switched the ring main off to change a socket,reinstated the power only to find there is no led power light on the TV,fuse okay,socket ok.
Hi Dave ,
It happens many a times to us also. Long back when I was learning electronics, a great teacher taught us to check and recheck what we have done. I request you to please do the same.
Good Luck.
Panasonic Viera P42X50B not working
Just try a reset to this TV.
To do a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so.This procedure will make it a hard reset.If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option.If you wish to get some details; check the site linked here.Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given.Never forget to exit the service mode, after all adjustments have been done.
Repair power board
How do you know that it's the problem? Do you hear the relays come on? Does your tv blink? How many blinks? That is a vital part in diagnosing a panasonic tv.
Regards,
Joseph Van Buren
On panasonic viera tx 32 Lx where can I turn off TV speakers sotahat I can play sound through denon sound system
When you plug in to the aux audio jack, that cuts out the speakers automatically. There is no switch.
1helpful
I have a tx-p42x50b when I turned it on nothing no green or red just dead
In fact the TV is Dead. It will be best to contact any service technician in this case, as work with Plasmas are very skilled one. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
1helpful
How do i remove the narration from my panasonic 42 in tx-42x50b
Panasonic Viera TX-L32X20B no channel found
the problem looks like bad main board , try to do the auto program , and see if it works , if dont work main signal board need to be replace
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
