If the Sylvania tv is a CRT (old style tube tv) you can just use an RCA cable and hook it into the composite video. It will be the cable that has a red, white and yellow connectors on it. The yellow is the video, the red is the right audio and the white is the left audio. Connect ones side of this cable to the output of the DVD/TAPE player and to the input on the TV side.
SOURCE: I don't know where to put the yellow, red and white connectors on the TV or the dvw
look on the back of your flat screen , there is a panel with inputs , example: VIDEO 1 , VIDEO 2 , etc. , connect your yellow , red & white from the DVD COMBO to video 1 (input) there colored to match with your cable , yellow w/ yellow , red w/ red , white w/ white , hope this helps AJ
SOURCE: need a manual for DVW 6100
There doesn't appear to be an online manual for this particular model, but the instructions for the DVW 7100 should be similar. Below I have posted a link to download this manual.
http://safemanuals.com/314159.php?k=647cfe42a45de0278188ca65329d258f&ID=334386&q=SANYO%20DVW-7100A&cM=-1
I hope this helps (and works!)
Der Strom
SOURCE: uei code for sanyo dvw-6100
It would help a lot more if you would specify which UEI Remote you had, but here are some instructions.
1. Go to http://www.urcsupport.com/
2. Select the remote model that is yours
3. Try the "Video-DVD" and the "Video-VCR" to determine which code will work.
Hope that this will help
SOURCE: I have lost the remote
You may not be able to buy a replacement original remote for it, but a universal remote may work - it is then a matter of code (if needed) to operate most of the basic functions of your combo. You could always look on eBay amazon, or ask your local store about the universal remote. Logitech are the best universal remotes on the market - these range from basic types to all-in-one, with the price of each varying. You should be able to buy something like that locally (similar brand to Logitech which will serve the same purpose) - if Sanyo won't put an order for the original remote in for you.
SOURCE: Wrong Region code
Hello, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay_vcbng
