Crown CE1000 2-Channel Amplifier Logo
A
Anonymous Posted on Sep 03, 2014
Why fan stop working
Fan dont work an amp over heats
Audio Service Clinic
Level 3:
  • Crown Master 924 Answers
  • Posted on Dec 06, 2014
Crown Master
Level 3:
Answers
924
Questions
Helped
351207
Points
1710
If the fan is not working, it could be the fan itself, or it could be missing the voltage to drive it. I wouldn't use the amp with this condition, as you may cause output failure. If you need more information, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
My crown ce1000 fan stop working dont no why
Check for broken wires, Or if that is not the problem fan could be burnt out. Also check if there is a separate fuse for the fan.
1helpful
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 • Ovens
I have a GE JES831WB 001 microwave that I'd love to fix. The light, clock & timer are working, but that's all - no fan nor heating. Any suggestions?
The door switches are often a problem, one or two are probably defective which would cause the symptoms that you are describing.
The compass and cruise control first started to work only intermittently and now dont work at all. Now the fan for the heating and air cond also stopped working
Look for a fuse for the Cruise Control and compass.
Also, the fan for the heating and air conditioning usually wears out (brushes get worn out) and possibly requires a relay as well to make it work reliably.
I don't think the two conditions Cruise Control vs. the Ventilation Fan are related.
1helpful
2answers
My 1998 ford taurus overheats when idling but cools down when you drive what should I do?
Check your your radiator cooling fan should come on at about 220 deg. and off at about 210 deg. at idle with a/c off, if it stats to over heat turn a/c on, fan should come on right away, if it dont check voltage at fan motor, if you do have voltage, you have a bad radiator fan motor, more then likely the reason it don't over heat while driving is air is being push through radiator where it cool's the coolant before it goes back into the engine, at stop's no air running through and never cool's coolant .
1helpful
My fan stopped working in my Acer Aspire 5515....how do I fix this?
Hi there, 1st of all ilike to know that is your laptop working or not? if its working & only fan is not working then, remove the back cover in your laptop, then remove the fan .Dont forget to disconnect the fan first from motherboard. After that replace it with new fan. Thanks& waiting for your feedback.
Jenn Air cooktop JED8430ADB not heating, fan & knob lights work?
Some times a breaker can be partially tripped and not visible . You should try turning the breaker off and on several times.
always unplug electricity before attempting to repair on any electrical appliance
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Mike Cairns
Mike Cairns
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
