It is a kitchen aid 300 watt stand mixer
SOURCE: Kitchen Aid Stand Mixer won't release beater
I had this same problem as well. The beater was stuck like glue to the rotating arm, and it would not budge with any amount of pressure. I tried the cooking spray and it did nothing. But today I put a rag in hot/boiling water and then carefully wrapped it around the top of the beater. I let it sit for 10 minutes. Then I put the rag in hot water again and repeated the process for about another 5 minutes. When this was done, I covered the beater in a towel (to protect it) and forcefully tapped (ok... I pounded) it with the flat side of my meat tenderizer (it was all I had...you could use a mallet or hammer). It took a little bit of work because I had to hammer it from the bottom, then the side, then the top to get the little spoke guided through the shaft. But it did finally come off. After cleaning with hot water, I put the beater on again and noticed that it was still a little hard to get on/off. So, I put a little bit of veg. oil on it, and it seems to be better. Going forward, I will be sure to clean the top of the beater & arm after each use and then coat it with a little oil to keep from sticking. Best of luck!
SOURCE: Kitchen Aid Classic mixer
http://www.kitchenaid.com/custserv/faq.jsp?sectionId=222#troubleshooting
Check this link to the Kitchen Aid website. It answers your question very well.
SOURCE: the adjustment screw fell off
I know what you are talking about. That tiny screw in the KSM50 model to raise the beaters... there is one. I know what you mean, but I don't know how to tell you to fix it if it doesn't go back in easily. Find someone handy?
SOURCE: Kitchen aid stand mixer blades do not reach bottom of bowl
go to youtube type in ajustment on kitchen aids and it will show u step by step hope this helps
