Error 58 on my Sony UP-21 MD printer. What does it means and how to fix this. Sony printer (UP-21MD)
SOURCE: Internal Error DRAM-FUNC.c 58 R
Under warranty ring samsung to confirm, the error relates to comunication with the ram chip, probally not seated, but I think you might find in has a "in house" warranty which means they will come to you.
SOURCE: ERROR CODE "C7980". I HAVE ALREADY EMPTIED THE TONER WASTE. WHAT DOES IT MEAN AND HOW DO I FIX IT?
Hello sir; The code you display which means waste toner bottle full, just dump it .
SOURCE: My dell laser printer 1320c has printer error code
this error means
Replace DrumCart
091-935
Drum Full of
Waste Toner
The drum cartridge needs to be replaced. fro more information about how to remove it you can got to following link
http://support.dell.com/support/edocs/systems/3100cn/en/UG/section22.html#172399
Testimonial: "Thanks very much for your help I will now order a new drum cartridge."
SOURCE: Error code 51.23 on HP 3600n printer
Try replacing Laser/Scanner Unit. LSU's ARE replaceble. You just have to remove too many screws.
SOURCE: Error Code 6A00, printer not working MP830
Move you ink heads out of the way and look inside, you will see the waste ink sponges and a little white plastic flap that may be jammed in position, wiggle it a little to free it and then continue to move it to make sure its free. This should solve it for you.
