When Daylight Savings time changed last week, I attempted to adjust the clock on my Dacor ECS230 Wall Oven. The touch pad keys for the time functions (except Stop Time) were unresponsive. Other than that the ovens function normally. Any assistance would be greatly appreciated.
Bob Bowman
Thank You Canada Two your solution worked for my clock problem also. We lost power and when it returned I could not reset the clock. Shut off power over night and when returning power the next morning, the clock controls worked as they should.
Try turning the power off at the breaker for 12 hours.
I had the same problem, tried turning the power off for a few minutes but that did not fix the problem.
Leaving the power off overnight seems to have fixed it.
The "clock" key pad on the settings display is dead. The clock is now 8 minutes off and I cannot reset it. When the power went out a month ago, we could reset the time from daylight savings, but now we can't correct the clock.
Maybe it takes breaking the circuit to get a response??? who knows?
I have a C01 stuck key failure on a Dacor MORS130 oven. I have replaced the membrane switch panel, and that did not solve the problem. I suspect the Oven control board. Is the most comon failure on this board the microcontroller? Is it possible to get a schematic anywhere?
