Fouling plugs due to rich mixture.
There should be an adjustment screw that looks like a "t" on the side of each carb. Screw it in 1/8th turn at a time to lean it out. Too much and engine detonation. I would recommend getting the retrofit kit to block off the oil tank and run mix fuel. Then there are no issues with too lean/rich, oil pump failure, plugged oil filter, broken or collapsed oil lines etc.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
