Book says right door left door...I don't understand.
SOURCE: we have recently installed this
As long as you can hear it trying to engage the lock I would say that you need to adjust the strike plate in the door frame for a more precise fit' You can use your key to lock the door and see if you feel any rough spots when it is engaging the strike plate.One easy way to tell where it is hitting if you can't see it is to use a magic marker and mark the strike plate. Try to close the lock with the keypad after the ink has dried. If it is hitting the strike plate it should leave a mark in the ink so you know which way you need to adjust the plate.. You can either move the entire strike plate or you can use a rat tail or round file to make it fit. If you have a dremel tool they work well with a metal circular file bit.Hope this helps you. Thanks.
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
