Mounted in a Four Winds 2007 Chateau 31 P motor home.
According to Atwood: No. Your Atwood Water Heater is made of a special aluminum alloy that does not require the use of an anode rod. Even though there are people who may tell you an anode rod is required you should not use one in our product it can actually harm the tank and would not be beneficial. If you are under warranty adding an anode rod will void your warranty. See here: http://www.askforatwood.com/faq.asp
Yes
http://waterheatertimer.org/Atwood-water-heater-resources.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
