Watches Logo
A
Anonymous Posted on Sep 02, 2014
What number of the battery model a15542
Need new battery
1helpful
2answers
Seiko dive watch - s/n 530687 8123-7190 What battery does this watch take?
Unfortunately, the Seiko website does not have a serial number lookup, so you'll have to identify the model. The "8123-7190" is what Seiko calls the "caliber code." Entering that on the page linked below will narrow down the model number list for you. Clicking on the link for your model will give you the instructions in PDF format. The instructions for your model tell you what size battery to use. For example, the manual for the 8F32 states on page 11 that the battery size for that model is CR2412. (Note - be sure to get the correct instructions; different models have different battery sizes.) "Automatic" Divers watches have no battery, they are powered by a spring mechanism.
1helpful
What is the battery specifications for DKNY ladies Watch NY3971?
If you look at the movement inside the watch it should be possible to find the movement number (you might need a loupe or magnifying glass to see it clearly) and name (e,g, Seiko-Epson, Miyota etc.)
If you can supply that information I can tell you which battery it requires.
2answers
What battery goes to guess watch model number U11502G4 model?
if it needs a new battery you will be better off taking it with you to a shop that sells watch battery's as 90% of the time they will fit it for free too ( and if they open it to see which battery it needs and they dont have one then get the model number while its apart )
2helpful
Need to add links to a new Elgin watch band. The number on back of watch is SR626sw
That's the battery number for the watch also known as the #377. It's the most common watch battery in the world. Your model number is located at the bottom of the dial (face) below the six-o'clock position. You will need a 10 power jeweler's loupe or magnifying glass to see it and read it. Jot down the number and contact Elgin directly (MZ Berger Co,) for the extra links.
MZ Berger.
Jun 20, 2011 • Watches
Battery number for my invicta model 2416
You should beable to pop the back off to see battery number or places like wally world etc.. will replace the battery for just the cost of the new one no labor
Seiko watch ser#687612,need a new battery,need to know which one
Hi there, can you look on the back of the watch for the model number. It should be similar to 7T62-0AC0 - I can then tell you which battery you require -
I need to know battery number for this watch.
Give us : make, model and all the writings on caseback. Photo will make it easy as well.
Need battery model number
the size cell that goes in this watch is a 395...good luck :)
1helpful
2answers
Fossil Fs 4296
Yes, your watch definetely needs a new battery. Find your nearest watch repair shop and ask to replace battery. Your watch will tick as brand new.:))
Top Nautica Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Nautica Watch Expert? Answer questions, earn points and help others
