Computers & Internet Logo
A
Anonymous Posted on Sep 02, 2014
Hawking Hi-Gain Wireless 300N Range Extender Pro installation
How to set up per user's manual?
Anonymous232
Level 3:
Genius:
  • Master 1,552 Answers
  • Posted on May 11, 2015
Anonymous232
Master
Level 3:
Genius:
Answers
1552
Questions
Helped
269986
Points
2945
How far did you get when you followed the user's manual?
What stumped you?
4 Related Answers
Anonymous
  • 2961 Answers
  • Posted on Jan 22, 2007
SOURCE: Default user name/password.
Try username as admin and password 1234
Anonymous
  • Posted on Dec 31, 2008
SOURCE: hawking extender hangs
They just issued new firmware: http://www.hawkingtech.com/support/details.php?CatID=32&FamID=105&ProdID=394#Firmware
You might try that...
-Tom-
Anonymous
  • 9 Answers
  • Posted on Aug 10, 2010
SOURCE: conecting g range wireless extender
follow the instructions for set-up comes with the belkin and make sure wireless channel are the same on belkin and sky.
Ezrahite
Rofel Lantican
  • 2632 Answers
  • Posted on Apr 28, 2011
SOURCE: HI I Have a Hawking
Welcome to Fixya. Have you tried to power cycle the router to refresh the ipaddress and can you please make sure that you're trying to connect to your Network Name, If it requires you with a password make sure you type the right password or Network Key. Network Key is case sensitive. You can obtain the information when you access the router.
If you have questions please let me know. Thanks for using Fixya
Hawking smart repeater pro
I CAN FIX THIS WITH A REMOTE CONNECTION...call 225-290-5733
2answers
Hwern1 hi gain wireless 300n range extender
what issue are you facing? its not connecting to your existing wifi network ? let me know if you want me to call you if u r in US
I cannot switch off the DHCP in the WL330 sitecom
You can find the user manual here: http://www.sitecom.com/wireless-range-extender-300n/p/714. I don't know your specific software, but on mine you have to click on every page to save changes. If you make all changes then save it will not save all changes.
How to setup up for repeater mode
This particular Hawking device must be configured after it is connected to your LAN and powered up.
Before you can do this, you will need the software from Hawking. If your devices Serial Number begins with HEMCHWREN1 use the link below"
http://hawkingtech.com/products/downloadfile/114.html
If you have a Revision 1 device with a Serial Number begins with HEMCREN1R1 use this link:
http://hawkingtech.com/products/downloadfile/117.html
Once you have the software, here are the steps you need to follow:
  1. Connect the A/C power adapter to an
    electrical source, and then connect it to the
    'Power' socket of the Range Extender.
  2. Connect your Range Extender to a LAN
    port on the Router or AP that you would
    like to extend (repeat) the range on.
  3. Connect your PC to any of the LAN ports
    located on the back of your router/AP.
  4. Now run the appropriate program you obtained from the instructions in the beginning of the answer.
When the auto-load page appears, click the Setup Wizard option on the right and follow the Setup directions.
Scan for your Range Extender by clicking the 'Search' button. Once found, click the device to highlight it and click 'Next".
Choose a name for your Range Extender. You will use this name to identify and connect to your extended network. Optionally, you may change your login username and password. Click 'Next'.
At this point, the Setup Wizard should automatically obtain a new IP address for your Range Extender from the Router. Please wait for this IP to generate into the IP address field. Note the new IP address and click 'Next' to continue.
In the Search box, find the Wireless Network that you would like to extend. This Range Extender works best with other wireless-N networks, but also supports wireless-B and G networks as well. Select your preferred network and then click 'Next'.
For Security Settings, you must make sure that the Range Extender's security settings are identical to that of the Router/AP that is having the signal extended. If you do not know these settings please contact your network administrator.
At this point the Setup Summary displays all configured settings of the Range Extender. If the information displayed corresponds to your desired networks settings, you can go ahead and click 'SET' to apply the settings. The HWREN1 will automatically reboot. Please be patient.
More information can be obtained on the hawking site:
http://hawkingtech.com/products/hi-gain_wireless_networking/range_extenders_&_repeaters/hwren1.html
1helpful
2answers
What range expander should I use with a Linksys Dual Band Wireless-N Router Model WRT 320N?
For this router you can use the Linksys range expander model WRE54G v3 take not of the version number that is important since the older range expander don;t work on all routers.
3helpful
Wireless extender Hawking 300N. Can you tell me what color the wireless connection light should be, green or yellow? If green what does yellow emply, on steady but not blinking even during operation?...
Green is good, yellow you can have several issues. The least obvious is a loopback which is usually caused when the primary wireless and the extender are duplicating IPs between themselves or another unit. This can also happen when two extenders come within range of one another or when the extender is also used as a wireless node and the IP range is the same as the primary network.
Grand Canyon Tech
Grand Canyon Tech
