This is a repair website not s medical question website
Symptoms of osteoarthritis
Osteoarthritis can occur in any joint. However, the most commonly affected areas of the body include the:
spine, typically at the neck or lower back
The most common symptoms of osteoarthritis include:
Read More Information:
Osteoarthritis : Causes, Symptoms, Diagnosis and Treatment
Rheumatoid Arthritis?
Rheumatoid arthritis (RA) is an autoimmune disease where the body attacks the lining tissue of joints, causing chronic joint inflammation. While it primarily affects joints, it can also cause inflammation of organs, such as the lungs, eyes, skin, and heart.
About Osteoarthritis-
A type of joint disease that normally affects the large weight-bearing joints of the knees, hips and spine although smaller joints such as those in the fingers and neck may also be affected. It is not a normal part of ageing but is much more common in the elderly.
In osetoarthritis the cartilage loses its elasticity and becomes stiffer.
The changes negatively impact on the ability of cartilage to act as a shock absorber which in turn can decrease functionality of the joint.
About Rheumatoid arthritis-
An autoimmune disease that primarily affects the joints.
Immune system mistakenly attacks tissues of the synovium causing inflammation and thickening resulting in damage to cartilage, tendons, ligaments and bone.
Normally affects joints of wrist and hands.
If you require any information about any disease then visit :
Pre Reg Pharmacy Exam in UK Course and Practice Questions
Osteoarthritis (OA) is a condition that affects the whole joint including bone, cartilage, ligaments and muscles.
Osteoarthritis may include:
Rheumatoid arthritis (RA) is an autoimmune disease that causes pain and swelling of the joints. The normal role of your body\'s immune system is to fight off infections to keep you healthy. In an autoimmune disease, your immune system starts attacking your own healthy tissues. In RA, the immune system targets the lining of the joints, causing inflammation and joint damage. RA usually affects smaller joints, such as the joints in the hands and feet. However larger joints such as the hips and knees can also be affected.
