I have had this phone for over a year. No problem charging until today. It went dead, and when I put it on to charge, it wouldn't turn on. Why am I now getting a "NONSUPPORTED BATTERY - SEE USERS GUIDE" message. Help please!
SOURCE: extended battery not charging, displaying unsupported battery message
sounds like they sent you the wrong battery some how
SOURCE: i have a samsung sgh-u900
i have the same thing happen to my phone now...just got it......how do u charge you phone at the beginning???
SOURCE: Samsung SYNC Charging issue;
Just had a rand new samsun u900 soul deliveredand this has the same problem. Has anyone found a fix for this?
SOURCE: My samsung behold will not turn on or charge. please help
Hi,i think the problem is from the batterry contact with the phone,
try using your battery with another phone of its kind,if it come on then the problem is not from your battery,or better still try packing the battery contact behind the phone with a piece of tissue paper,if it comes on then the problem is from the battery contact which probably have shifted as a result of you rolling on it.
you might have to contact o phone repairer to help you tighten it,or if you have the tools and think you can do it yourself,go on,but you have to be very carefull
take care
Testimonial: "Thank you so much"
SOURCE: Samsung Jet Cell Phone is "dead"
under warranty will not count on liquid damage if you take the battery out you will see a red dot that tells you water damage i have dried out some mobiles take out battery and sim leave on warm radiator couple of days then try again if still the same then it spares cost way too much to put right needs mother board ,and connectors hope this helps
