Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Will not turn on as in completely dead, no lights, nothing, or does it try to start up, but never finishes and switches itself off ? 4.September.2014Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Will not turn on as in completely dead, no lights, nothing, or does it try to start up, but never finishes and switches itself off ?
4.September.2014
You can't post conmments that contain an email address.
Maybe the system cannot detect the memory well. Reinserting the memory card maybe cure the problem. (Note!: Do not remove the memory card/s while the unit is running.) Insert the RAM card/s properly and test if there's good result.hope this can help you.
when turning on the system go into the BIOS and reset back the seeting s to factory defaults and reboot the system .. If this fails then reseat the Hard drive may have come loose or ?
did you recently add new software ? drivers ? hardware?
to reset the ds to factory settings, you will need a screwdriver. on the back of the ds is a little panel, just unscrew that, take the cover off and that that should reveal the battery pack. then all you need to do is take out the battery for a few seconds and stick it back in. put the cover back in and the next time you turn on the ds you will need to input all the data again as if you bought it for the first time.
These are the normal steps on desktop computers but
should work in your case too with a fresh installation
1. Enter bios settings and set CD Drive as first boot device
2. After reboot if you are asked if you want to start on cd chose yes.
4.September.2014
