We have replaced the graphics card and inserted a brand new battery for the BIOS, but yet the six beeps continue upon powering up.
SOURCE: bios problem
Standard Original IBM POST Error Codes1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
PCHELL.COM Newsletter
If you would have read my E-book on Internet Security, you may not have ended up in PCHELL. Join the PCHELL.com mailing list and receive your free E-book now.
Name:
Email:
Tools for Removing Spyware, Adware, and Malware
PC HELL
Other Pages
Spyware/Adware Removal Help
MSBlast.exe Worm Removal
Welchia (Dllhost.exe and SVCHost.exe) Worm Removal
Uninstall McAfee Instructions
Uninstall Norton Instructions
Uninstall Avast Instructions
Uninstall AVG Instructions
Uninstall Antivir Instructions
How to Manually Run the Microsoft Malicious Software Removal Tool
Bloodhound.Exploit.6 Virus Removal
MyDoom Virus Removal
MiMail.C Virus Removal
Swen Worm Virus Removal
SoBig.F Worm Removal
Dumaru Virus Removal
BugBear.B Worm Removal
SoBig.E Worm Removal
Pop Up Ad Removal Info
KAK Worm Removal
MiMail.A Worm Removal
W95.MTX Virus Removal
Snow White Virus Removal
BadTrans Trojan Removal
Wininit Virus (Bymer Trojan)
Happy99 Worm Removal
VBS Netlog Worm Removal
Pretty Park Worm Removal
Sasser Worm Virus Removal
Backdoor SDBot.H Trojan Removal
VBS.Loveletter Help
Computer Security Information
Back Orifice Information
PC HELL Main Page
IBM POST Diagnostic Code Descriptions
100 - 199 System Board
200 - 299 Memory
300 - 399 Keyboard
400 - 499 Monochrome Display
500 - 599 Color/Graphics Display
600 - 699 Floppy-disk drive and/or Adapter
700 - 799 Math Coprocessor
900 - 999 Parallel Printer Port
1000 - 1099 Alternate Printer Adapter
1100 - 1299 Asynchronous Communication Device, Adapter, or Port
1300 - 1399 Game Port
1400 - 1499 Color/Graphics Printer
1500 - 1599 Synchronous Communication Device, Adapter, or Port
1700 - 1799 Hard Drive and/or Adapter
1800 - 1899 Expansion Unit (XT)
2000 - 2199 Bisynchronous Communication Adapter
2400 - 2599 EGA system-board Video (MCA)
3000 - 3199 LAN Adapter
4800 - 4999 Internal Modem
7000 - 7099 Phoenix BIOS Chips
7300 - 7399 3.5" Disk Drive
8900 - 8999 MIDI Adapter
11200 - 11299 SCSI Adapter
21000 - 21099 SCSI Fixed Disk and Controller
21500 - 21599 SCSI CD-ROM System
AMI BIOS Beep Codes
1 Short Beep One beep is good! Everything is ok, that is if you see things on the screen. If you don't see anything, check your monitor and video card first. Is everything connected? If they seem fine, your motherboard has some bad chips on it. First reset the SIMM's and reboot. If it does the same thing, one of the memory chips on the motherboard are bad, and you most likely need to get another motherboard since these chips are soldered on.
2 Short Beeps Your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard.
3 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above.
4 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above. It could also be a bad timer
5 Short Beeps Your motherboard is complaining. Try reseating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade!
6 Short Beeps The chip on your motherboard that controls your keyboard (A20 gate) isn't working. First try another keyboard. If it doesn't help, reseat the chip that controls the keyboard, if it isn't soldered in. If it still beeps, replace the chip if possible. Replace the motherboard if it is soldered in.
7 Short Beeps Your CPU broke overnight. Its no good. Either replace the CPU, or buy another motherboard.
8 Short Beeps Your video card isn't working. Make sure it is seated well in the bus. If it still beeps, either the whole card is bad or the memory on it is. Best bet is to install another video card.
9 Short Beeps Your BIOS is bad. Reseat or Replace the BIOS.
10 Short Beeps Your problem lies deep inside the CMOS. All chips associated with the CMOS will likely have to be replaced. Your best bet is to get a new motherboard.
11 Short Beeps Your problem is in the Cache Memory chips on the motherboard. Reseat or Replace these chips.
1 Long, 3 Short Beeps You've probably just added memory to the motherboard since this is a conventional or extended memory failure. Generally this is caused by a memory chip that is not seated properly. Reseat the memory chips.
1 Long, 8 Short Beeps Display / retrace test failed. Reseat the video card.
SOURCE: hp xw6200, 6 beeps, and red power button...failed start up.
6 long beeps indicates that there is a problem with the memory, take them out, clean the contacts and the DIMM slots and reseat them.
Hopefully this will resolve the problem, if not new memory may be required
kind regards
SOURCE: pc beeps five times when swtched on
PC beeps are usually memory-related problems. make sure you are using the right memory for your computer. the specs should be a DDR2 DIMM 240 pin PC2-3200. what specs do you have?
also do you have two 1G memory sticks or just one 2G memory stick? it may be that your computer doesn't accept a 2G memory stick but rather 1G memory sticks. good luck.
SOURCE: bios error beep code HP
Hey ByteGuy, Saw your solution to a premium where you asked the customer to contact you with ask me, I have to admit that was a good way to communicate before but now, if you go ahead and click ask me on my profile, you will find that it takes you to a 9.99 and 19.99 usd page instead of a free request.
Just a heads up.
Thanks,
Ekse
SOURCE: BIOS ROM Checksum Error - no POST, no beeps, no display -HELP!
If your computer turns on and no display then you have faulty memory cards, replace them with new ones and make sure you use the right kind. Bios settings are usually set to default and factory settings, you should not have to update them. Usually if you hear no beeps when you turn on the computer, then your memory cards are faulty. I hope this helps.
