My Eco drive watch acts as if the Daylight Savivgs feature is not workig properly, I set the time turn the feature on all is good, wake up the next morning and it's an exzactly 1hour behind, I check to see if the feature is still on and it is. What could be happening?
The time on these watches has to be first properly referenced to UTC. I do not have the instruction book for your watch or even have a clue to the model number since you did not put any model number. There are several dozen Eco Drive models in each of the Citizen and Casio, and other type watches that are solar powered.
I have several types of Sky Hawk watches in the Citizen, and similar ones in the Casio. Check your instruction manual about how to set the UTC time, and how to set the offset time for your location. Once properly set up your watch should stay on time. If you have the radio receiver in your watch for the auto time setting, once the watch is set up properly it will maintain proper time all the time.
SOURCE: Setting the time on a Citizen Eco-Drive Watch
Go to this link and pay particular instructions on how to find your watches movement or caliber number.
http://www.citizenwatch.com/COA/English/settings.asp
SOURCE: Setting time/date on Ironman Triathlon 8 lap
Press & hold set button the seconds will flash.
Press split/reset to set seconds to zero
Press mode to select hours
Press split reset to advance hour digits go through 12 hours to get to AM/PM
Press mode to select minutes
Press split reset to advance minutes
Keep repeatin the above steps to set month date day and 12/24 hour diplay
Press set when done.
SOURCE: Daylight Saving Time will not set correctly
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
SOURCE: Citizen Eco-Drive Skyhawk JR 3060-59F
Paste this link into your browser and follow instructions:
http://www.citizenwatch.com/CUK/English/settings_int.asp?caliber=C650&interactive=C650
If this is not the correct caliber number, click on technical support tab in the same webpage and find the right one for your watch.
DO NOT FORGET TO RATE, PLEASE.
SOURCE: Citizen Aqualand eco drive divers watch.
Leave your watch on window sill (sunshine must be plenty) for a week. If the watch will not keep charge after that, visit your closest watch repair shop and ask to replace capacitor. Rate me, plz.
Testimonial: "THANKS ALOT FOR YOUR HELPFUL INFO AND I WILL TRY THIS. MUCH APPRECIATED."
