Cars & Trucks Logo
Tammy Lawrey-Watson Posted on Sep 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for a manual for 1999 ezgo electric golf cart. Anyone?
I'm looking for a free manual for a 1999 EZGO txt electric golf cart. I've been looking online all morning and can't find one. Does anyone know where I can get one? Thank you!
Hank Bondurant
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jan 05, 2015
Hank Bondurant
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
26389
Points
25
Batteries are DEAD.
carlos falero
Level 3:
Genius:
  • Cars & Trucks Master 1,327 Answers
  • Posted on Sep 02, 2014
 carlos falero
Level 3:
Genius:
Answers
1327
Questions
Helped
349056
Points
2968
5 Related Answers
Anonymous
  • 166 Answers
  • Posted on Mar 07, 2010
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
golfcartman
  • 34 Answers
  • Posted on Apr 21, 2010
SOURCE: I need a wiring diagram for a 1986 ezgo golf cart,
use this link http://www.vintagegolfcartparts.com/cgi-bin/gallery/gallery.cgi?func=show&file=200332&Category=100013&Page=1
golfcartman
  • 34 Answers
  • Posted on Apr 22, 2010
SOURCE: Rear axle fluid for 1983 ez go electric golf cart?
Regular 90 weight gear oil. Fill until it reaches the fill hole.
Hank, The cart man
golfcartman
  • 34 Answers
SOURCE: 1999 ezgo golf cart.need to know the whole wireing
When you removed the batteries, a certain procedure MUST be followed. Key switch off, switch to tow position and shift lever in reverse. You must wait until the beeper unit sound dies out then remove the wire from the most NEGATIVE cable. Place in Neutral before installing new batteries. There is a specific sequence to putting the batteries in an EZ-GO cart. Failure to follow this procedure will kill the controller. The Key switch must be off and the maintenance/tow switch MUST be in the tow position when connecting the batteries. Any of the above will cause the controller to fail, due to improper discharge of the PRE-Charge capacitors.
golfcartman
  • 34 Answers
  • Posted on Apr 24, 2010
SOURCE: EZGO golf cart won't go forward
Your batteries have died. The reason it will barely move in reverse is that current is being supplied to the motor is a direction that it spends very little time using. There is a slight change in the armature over time, and reverse tends to work better over time. Check the voltage when under load. (run jumper wires from the + and - of the battery bank. If it is a 36 volt cart and the voltage drops to below 36 volts, you do not have enoug current to run the cart. Plug in the charger and watch the ampmeter. If it goes up to about 20 amps, then it is charging. It should take a good charge after 10 hours. If the cart charges and only runs a short distance, the batteries need replacing.
2011 alumacar electric accelerator switch supplier.also service manual
Perhaps one of these will fit or can be wired to fit?
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk03CYd1A8u0VWqoGY_BtHP7_7W2SMg%3A1614309283863&ei=o2c4YNumNLiKwbkPqNGtkAg&q=2011+alumacar+electric+accelerator+switch+replacement
This looks like the only place that might have a service manual? Alumacar appears to be a very small business and also made aluminium trailers. Not much on them at all.
Golf Cart Service Manuals - All Makes and Models - Pete's ...
https://petesgolfcarts.com > general-golf-cart-ownership
Feb. 16, 2019 - Aluma Car Service Manuals; Club Car Service Manuals; Columbia Par Car Service Manuals; Ezgo Service Manuals; Fairplay Service Manuals ...
There a few pictures here
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk004sL6hlRfVbRfeKBZ9ghETu4mzng%3A1614309509456&ei=hWg4YJO7G5iWwbkPxYel2A8&q=2011+alumacar
HOW TO GET THE PART NUMBER FOR THE REAR BRAKE SHOES FOR MY RUFF AND TUFF GOLF CART
E-Z-GO Golf Cart Brake Shoes - Genuine E-Z-GO Parts and Accessories
https://shop.ezgo.com > Shop > Parts > Brake Parts > Brake ShoesOEM Golf Cart Brake Shoe 4084 ' Single Shoe. Fits 1996-current E-Z-GO Golf Car and Utility Gas & Electric Vehicles. Item #: 648037. $24.70/ea. Spring- Shoe Return- LH (Blue). Used on 1996-Current E-Z-GO Gas & Electric 4/6 Passenger Shuttle, ST Express, 875, 881, 950, and Cushman Titan Vehicles; in addition to ...
I do not know how to start my ezgo electric golf cart 2001 no one showed me how to start it just said here it is drive it and left so it is in great running condition what are the steps to turn it on
Product Manuals
Click on the link above and when you get to the page, select your specific golf cart and you can read the manual. It should explain everything you need to know.
Semper Fi,
Z
Need a manual for my 1990ezgo golf cart free printable please showing pictures of the carb and filter and gas lines
Visit the on-line store, know as reliable-store, they have the repair, parts and operating manuals. I'm sure you will get the solution of your problem.
ezgo golf
Ez golf cart when I go up steep hill the cart loose power and smoke White smoke
Basic EZGO Golf Cart Problems And How To Fix -
www.golfcarthotrod.com > Golf Cart Repair
Apr 30, 2010 - Electric E-Z-Go Golf Carts are becoming more popular every day ..... I have a ezgo carryall gas golfcart. it has began to pour smoke from rear.
1helpful
Ezgo txt golf cart was running fine till friend power washed it
It depends on the symptoms. I would check (or have checked) the battery compartment, power connections and the electric motors.
And why are you posting the question and not your friend whom broke it?
Do i need to mix the gas in my 1988 ezgo
Most people do not trust the old oil pump used on the 3PG models, me included. Mix 50:1 and you can be sure that the piston and crank will not seize up.
1helpful
Hank, The cart man
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
