What is a dingos habitat
Dingo Facts
http://www.softschools.com/facts/animals/dingo_facts/277
https://www.australiazoo.com.au/our-animals/mammals/dingoes
Wide range of habitats, including living in abandoned rabbit burrows and hollow logs
SOURCE: dingo by manco
most likely the spring you are looking for is located on the torque converter. if you remove the plastic housing, the lower disc that is attached to the engine by the belt (not the chain) there should be a spring on the outside of it. hope this helped.
SOURCE: how do i defeat dingo in third mission
First of all, blast the hell out of his shield while you are fighting him. I find the best way to do this is to repeatedly fire while also launching grenades. Eventually, his shield will break, and you will have a very little bit of time. When his shield breaks, go all out!! Use all the bullets and grenades you can as quickly as you can, and you should be able to win.
SOURCE: Toro Dingo TX420 steering is labored and stiff.
Dissaemble the steering and clean out the rust and corrosion that is causing the stiff steering. It would be cool to have a pool full of wd40 you could soak it in :) hope this helps. Let us know how it turns out
