PRO 41 10 Channel Programmable Scanner 200 0301 Operation here is a link to instructions on how to unlock the channels or reset your device, hope this helps
SOURCE: Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
SOURCE: all channels locked out pro-2055
I hope this will help. It shows locking and unlocking ids while scanning and while in a bank.
Locking/Unlocking IDs
Contents
You can lock out IDs you don't want to hear such as telemetry, MDT's, dog catcher, etc.
To Lock out an ID while scanning, quickly press L/OUT while the ID is displayed.
To Lock or Unlock an ID manually:
1. In Manual mode select any channel of the bank you want to lock or unlock an ID in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel.
2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the bank number (0-9), list number (0-4), and the list status (ON or OFF) on the 1st line, the ID# in the list (0-29) on the 2nd line, the ID on the 3rd line, and bank tag on the 4th line (if programmed).
3. Press TRUNK (each time) to select the ID list (0-4).
4. Select the ID# (0-29) by pressing or (or press and hold; faster) then press L/OUT to lock or unlock the ID. An L will appear to the right of the ID# if the ID is locked out.
5. Press MAN to exit programming.
To Unlock IDs in a bank:
1. In Manual mode select any channel of the bank you want to view the locked out IDs in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel.
2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the ID list.
3. Press FUNC then L/OUT (each time) to view the locked IDs. Press L/OUT to unlock the ID. The next locked out ID will appear.
4. Press MAN to exit programming.
Note: You cannot unlock all IDs at one time.
SOURCE: clearing out old channels on a radio shack pro 95 scanner
Turn it on, and when "Welcome" appears, press zero, then press one. It will display a message indicating it is initializing to the factory state.
SOURCE: how to program freqencies on
Wow, that's a real oldie -- circa 1981. To program it:
1. Power the scanner ON.
2. Press MANUAL .
3. Select the channel that you wish to program. You can do this by repeatedly pressing the MANUAL key, or enter the desired channel (01 - 20) followed by the MANUAL key.
4. Press PROGRAM.
5. Enter the desired frequeny, including the decimal point (e.g., 156.55).
6. Presto ENTER.
7. To program more frequencies, press PROGRAM and then repeat steps 2 through 6.
Follow this link for more operating instructions:
http://support.radioshack.com/support_electronics/doc45/45530.htm
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
SOURCE: I have a radio Shack
Hello waltz,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
1. Press the SRCH button.
2. Select the bank you want to clear all locked-out frequencies.
3. Press the FUNC, L/OUT. Lockout list will appear.
4. Press 6. Confirm list clear? 1=yes, press another key for no.
5. Press 1 to clear all.
I hope this solution was very helpful to your problem.
Thank you for choosing FixYa.
John
