B330
Lift the pressue foot off the fabric. Hold the thread spool with one hand and lightly pull the thread hanging out the back of the needle. This should seat the tread into your top tension discs properly. Now try sewing again. If it still throws loops, you either do not have your machine threaded correctly or your tension on top is set to zero.
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
SOURCE: Singer 301a...sews on top of fabric
This is a tension adjustment problem. It's good to use two different colors of thread, like you did. From your description, the top thread (needle thread) tension needs to be tighter. As you tighten the tension of the top thread, you'll see that the top thread pulls the bobbin thread up into the fabric so it's no longer laying loose on the bottom of the fabric.
You'll need to have the pressure foot down when you tighten the tension. Tighten it a little, sew a practice seam, check to see what the stitch looks like. Tighten it a little more, sew, check, etc etc--until both top and bottom look the same--you shouldn't see much (if any) of the bobbin thread color on top of the fabric or the top thread color on the underside.
Let me know how this works for you, ok?
Robbie
SOURCE: I think the bobbin tension is off - I have large
It sounds crazy but if you have loops on the underside of your fabric it means your upper thread is not properly threaded (and vice versa for loops on the top of your fabric). So re-thread your top thread, change to a new needle if you've been sewing with it for a months and you should be good to go. Let me know if you need any more help.
Testimonial: "thanks for the suggestion. My sister-in-law suggested trying a new bobbin and rethreading - which together worked."
