Future Beach Spirit 120 Kayak Lime Green W/paddle Lime Logo
A
Anonymous Posted on Sep 01, 2014
<!-- from fixya rte -->How to plug scupper holes in kayak? - Future Beach Spirit 120 Kayak Lime Green W/paddle Lime
vpsoccer
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Expert 284 Answers
  • Posted on Aug 04, 2015
 vpsoccer
Expert
Level 2:
Passionate:
Answers
284
Questions
Helped
206990
Points
369
I am not sure what you mean, or why. Scuppers are designed to drain water from places you do not want it. On a sit-on-top like that they are designed so that water drains out of the cockpit where you are sitting. If you plug them, then the water that does get in will not drain out and you will have to bail/sponge it out or sit in the water.
The Fusion has no drain plug in the bow where it is needed. Since there is a slight center ridge along the bow deck and the Pyrahna plug has a flat base, where should an added plug be installed?
always on the bow deck area. be careful of too many openings in a kayak. you're life may depend on its flotation and a plug-hole is just another place for water to enter the hull. Not recommended.
tip
Tips for Choosing A Best Fishing Kayak
Best Fishing kayaks come in all different shapes and sizes and it's important that you choose the right one. Because not only will it let you get the most enjoyment out of your time on the water, it'll make you safer on the water.
When choosing a fishing kayak, narrowing down your options is actually pretty easy, and it starts with identifying how and where you'll be using it:
• Will you be fishing small sheltered bodies of water like ponds and small lakes?
• Or will you be taking the kayak on big bodies of water that are exposed to wind and waves?
• What's the water temperature going to be like?
• And when it comes to performance, is it more important to have a kayak that's fast and responsive?
• Or are you more concerned about having a kayak that is stable and difficult to tip over?
With these questions in mind your first and biggest decision will be whether to get a sit-inside kayak or a sit-on-top kayak.
Sit-on-top kayaks are the most user friendly fishing kayaks. They're very stable and easy to get in and out of, and there's no feeling of confinement on them. They're also self bailing, which means the water drains through small holes called scupper holes. They go right through the bottom of the kayak. This means you can't swamp a sit-on-top kayak. Another great safety feature is that sit-on-tops are much easier than sit-insides to get back on to from the water, if for some reason you fall off. The one downside to sit-on-top kayaks is that you're almost guaranteed to get wet while paddling, while sit-inside kayaks allow you to stay dry.
Sit-inside kayaks can be a good option for anglers who will be in cooler water, who want to stay dry while paddling, and who want a faster moving kayak. Just keep in mind that if you flip a sit-inside kayak, recovery is not necessarily a simple process because the kayak may swamp. As you're learning, try to stay in sheltered water or close to shore so you can swim in if you need to.
Once you've decided on whether to go for a sit-inside or sit-on-top kayak, you'll need to decide on a length for your fishing kayak. As a general rule, a long and narrow kayak will be faster, while a short and wide kayak will be slower but more stable. If you are only going to be fly fishing and sight casting, a short, wide, and stable boat is a great choice because standing is easy. The trade-off is that the kayak will be pretty slow and not ideal for paddling any real distance. On the flip side, if you want to cover more ground or maybe even troll offshore, you might want to choose a longer, narrower kayak that travels through the water more efficiently.
Once you decided on the style and size of kayak, there's one more key decision to make: Do you want a pedal kayak or do you want a paddle kayak? Traditionally kayaks are powered by paddles, but there are a number of companies that now offer pedal kayaks. One of the benefits of pedal kayaks is that they leave your hands free for fishing. The downside is that they're less maneuverable and heavier than other kayaks. The pedal system also works less efficiently in really shallow water. If you do decide on a pedal kayak, something to keep in mind is that it's very important you have a good paddle on board as a backup.
At this point you dramatically reduce your options, and most of your decisions will now impact the comfort of your kayak, and relate to features of convenience for the type of kayak fishing you're going to do.
Best Fishing Kayaks For Anglers In 2018
on Feb 28, 2018 • Boating
How can I determine why my is my Hurricane Phoenix 120 is leaking?
Inside the scupper holes which can't really be inspected, leaks can be a serious problem. some owner tie a rope thru the scupper holes to attach to a rack or other reason, but when the walls inside the scupper holes 'crack' there's no way to tell. Stand the kayak on end and fill with water. Look for leaks that way, by filling the whole tamale with water and inspect for water leaking out. Probably time to shop for a new one!
How to attach and use
Don't attach them. you will learn to keep upright by practice! If you drill holes, kayak will leak.
How to find leak in ocean kayak.
fill the kayak using a hose and the drain-hole. every ocean kayak has a drain-plug. with water going into the shell, any holes will show up. Drain water and use.
Plastic piece on back of seat busted looking where to find replacement its for a dirigo 120
I would say the best thing to do would remove the screws/bolts/hardware
plug the hole with whatever you took out. and buy a new seat with a higher back.
you may need to add those u shaped deck cleats but thats not a big deal
2answers
How 2 repair a whole in a kayak
buy some fiber glass and some ressin it is 2 to 1 in the ressencover the hole with a small sheat of fiber glass alittle bigger then the hole let it soke smeare it a little then add another coat let it dry for a bout 24 hours then you can sand it and paint it
Hole in my Kayak.
Plastic weld it or use plastic epoxy.
Top Future Beach Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Future Beach Boating Expert? Answer questions, earn points and help others
