Control lock stays on. Unplugged the washer control locked light still stays on and washer will not start. Cannot cancel or clear this light status,
There is normally a master reset sequence on most machines,,,info on how to do this should be in your manual
While the machine is 'on' press & hold the "end of cycle" button for 3 seconds, or till the lock light goes off. This is on the far left or right of the machine's panel. Good luck! Pl rate me.
SOURCE: Control Locked light is on...
OMG!! I just held the button at the end of cycle signal for about 3 seconds and the light went off! Now my washer is working!
Ok Yankee
SOURCE: ''Control Lock'' won't ''unlock''
Press and hold the "End of Cycle Signal" button to lock or unlock the control panel. The instructions should be printed directly below this button. I hope this helps you.
SOURCE: Control lock light on
take a good look on control panel i don't remember which button you should push and hold for 3 for 5 sec. to lock or unlock control panel (it also called child lock) let me know it help or not. thanks....
SOURCE: Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
SOURCE: Duet GHW9150P Front Load Washer: whirlpool washer says control locked, how can we f...
Press and hold "end of cycle" button for 3 seconds, on the right side
of panel. This is the child lock feature, do it again & it locks.
If
helped, pl rate me good!!
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however;
your whirlpool duet washer needs a reset to resolve the control lock problem.
Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset
the control. Please get back to me if you have any other questions.
Kevin
