Nostalgia Electrics Krs 2100 Keg O Rator Refrigerated Beverage Keg Dispenser Logo
A
Anonymous Posted on Sep 01, 2014
I need washers and thecho ke for a kegorator kRS-2100
I need washers and the choke which installs on the kep tap
How to install a Kenwood sterseo satellite reciever krs*1200p in my house
IT STATED SATELLITE,UNLESS ITS CONNECTED TO THE INTERNET,IT SHOULD NEED A SATELLITE DISH OR ANTENNA,
OTHERWISE IT CONECTS TO YOUE STREO SYSTEM.
HORST IN AUSSY LAND...
How long does a tapped keg of beer last?
This depends on the type of system you are using to tap your keg. A standard tap given to you with a keg will not last very long, just less than a week. If you are using a proper kegorator CO2 system, your beer will last at least two months, if not longer depending on the temperature of your fridge.
4answers
1helpful
2answers
I have a firefighting pump with a honda engine it
above the startercord there are 2 handles. top one is grey is choke , bottom is black, is fuel tap. first open fuel tap put on choke, start, after 5 or 10 seconds put choke off. if its not starting on choke, gets no fuel. under fueltap is chamber with 10 mil bolt. open and clean. also drain or take off floaterchamber of carb. this is the round cup under the carb. good luck.
Puncture hole in my kegorator
Yes, find a licensed refrigeration technician. They will solder the hole and recharge with refrigerant. It should then be as good as new (or however old it is).
1helpful
Idles high when choke is fully closed
You are running lean. it could be a leak in the intake track. a plugged carb passages and or jets. A leak in a crank seal or head or base gaskets. spraying carb clean in any of these areas will change the idle if it is leaking in that area
Top Nostalgia Electrics Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Nostalgia Electrics Refrigerator Expert? Answer questions, earn points and help others
