Computers & Internet Logo
A
Anonymous Posted on Sep 01, 2014
Sony cfs-905 will not run with ac adapter
Powers with batteries; no power with ac adapter
JOSELITO YARA
Level 1:
Habit-Forming:
New Friend:
  • Contributor 37 Answers
  • Posted on Sep 03, 2014
JOSELITO YARA
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
37
Questions
Helped
6278
Points
62
How can you charge the batteries from your unit if the AC power source cannot works in? Maybe the DC adapter socket's solders was cracked or loosed.
5 Related Answers
Anonymous
  • 133 Answers
  • Posted on Aug 02, 2007
SOURCE: IBM Thinkpad T30 no power
I agree with you and have a link for adapters http://www.google.com/products?q=IBM+ThinkPad+T30+2366+adapter&hl=en&rls=com.microsoft:en-us&um=1&sa=X&oi=froogle&ct=title
Anonymous
  • 2351 Answers
  • Posted on Mar 14, 2008
SOURCE: Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
Anonymous
  • 94 Answers
  • Posted on Mar 31, 2008
SOURCE: COMPAQ V2000 WILL NOT POWER UP WITH DC/ADAPTER OR BATTERY
After you have verified that the solder is good around the DC Jack >>>>
Check MOSFET (Anachip 4407 or Fairchild 4435) near DC JACK
[replace the pair PNP/NPN]
Check MAXIM IC (MAX1999)
Anonymous
  • 2028 Answers
  • Posted on Jun 21, 2008
SOURCE: Dell Inspirion 1526 Laptop Battery is not charging
Sound like the battery. Take the battery out and there should be a power meter on it, press it, if there are three lights that flash, the battery is shot. Not all batteries will flash if they are worn out, but they are supposed to. Try a new battery, I believe this will coorect the issue.
Anonymous
  • 163 Answers
  • Posted on Mar 14, 2010
SOURCE: Sony VAIO VGN-FE770G only runs on AC power, battery not working
This looks like the system is not able to sustain itself on the battery power. I have a doubt here. Is it a new or an old laptop. Either Case we have to suspect the battery charging and battery condition. One another reason could be that the battery contact is not good. But this could be of the least chance as the manufacturing of such devices would be perfect in all standards. Lets check the battery power first.
A sony Vaio never operates if the battery is not detected or the battery is not charging, while the system is up and running, you can see a small picture of the battery in the system tray which is at the right bottom corner of the screen. Run your mouse over the same and you will find a tooltiptext message and you can see if the battery is charging or not. If not, your hardware has a problem. If its charging but the battery charge is not increasing, then you have a battery problem. If its a battery problem and that the system is under warranty, you can well get a replacement for free. Hope this resolves the issue. Good Luck.
Testimonial: "Thank you for your help - I really appreciate it! My computer is 3 years old, so I suspect the battery is defective. "
Do you need a working battery to run camcorder off ac power adapter? I havent used camera in 2 years and just bought replaceable power adapter and wont charge battery or work off outlet at all..camera was...
You do not need a battery to run the camcorder off ac power supply. It is one or the other. The only time that both will be used is when you are charging the battery on the camcorder with the power off.
Hope this helps.
www.austintelstarservices.com
I only need the amperage for the adapter for a CFS 914 sony radio. Thank you
The adapter is an AC-905. The important bit is the 500 mAmp. The actual part number is 169301611
Screen is dead
  1. turn off the computer
  2. take off the ac adapter and remove the battery
  3. reseat RAM/memory
  4. without the ac adapter and battery, press and hold down the power botton for 7-10secs
  5. reconnect the battery and ac adapter
  6. try turning it on
hope this helps
My sony vgn-tx17p won't boot. Te power light turns on and nothing shows up on te screen. Please help
  2. disconnect the ac adapter and remove the battery
  3. reseat the RAM/memory.
  4. without the battery or ac adapter, press and hold down the power button for 7-10secs
Dead Sony Laptop
If power supply is supplying correct voltage, then you do not need power supply PCB.
Try starting the laptop with AC adapter and no battery, if battery is shorting out you may get same problem.
Test the soldering joint on the AC socket and laptop motherboard, if there is a bad soldering on laprop ac adapter socket, you get same symptoms.
If it is none of the above, and the adapter is fine, then it is usually a faulty motherboard.
Sony Vaio ac adapter submerged
If the ac adapter was plugged into the laptop at the time may be bad news. Unplug AC adapter, take out the battery and hold power button for 10 seconds. Then connect AC adapter and hit power. If that doesn't work put battery back in without ac adapter and hit power button.
If neither test works bring to repair center for diagnosis. Best case AC adapter would need replacing. Worst case Motherboard fried.
Thanks
Grand Canyon Tech
Grand Canyon Tech
