Power went out and is now on. Everything in the house works but the my Honeywell TH9421C1004. I have no batteries (that I can see). Looks like it plugs directly into the wall.
SOURCE: I went to put the heating on and my honeywell
Hello Bad news something in 6400unit has shorted!I would try replacement.
SOURCE: The thermostat worked correctly for months then
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need
SOURCE: My honeywell t8400c also went blank. I can not
it should take a battery and it has wires coming from the unit for power as well the stat splits open from the wall leaving some of it mounted on the wall the batteries are in the part that pulls off the wall and the wires are on the part that stays on the wall the power wire is red on r terminal
SOURCE: My door chime (Honeywell) is
The transformer may have been fried. test this with a line testing kit like you would use to trace a line in a car. If the power is not going threw the transformer then you can just replace it of by a new door bell. they are fairly in expensive.
SOURCE: honeywell T8011R
Had similar experience. Display off and no fan power. I replaced the unit after an hour and the display came on. I guess a pin needed to be reset (cleaned by wiping against contact). Hope it stays on.
